Another thing to try would be to use dark frames. Incorporating these into your processing should help reduce the noise.
What software did you use for stacking? DeepSkyStacker is good. Unless you want star trails, in which case try www.startrails.de
Also, what camera were you using? Some cameras are notorious for long exposure/high ISO noise. If you have to use ISO 200 then you probably aren't going to record much unless you go for 30 second exposures and then, with a standard 50mm lens without a tracking mount, each exposure will have star trails in it, so you won't be able to get deep sky objects or stars that appear as points. To eliminate the trails without a tracked mount, you need to go for a wide angle lens and get more light in, which means a faster lens or a higher ISO, so that you can minimise the shutter speed. If you can use ISO 1600 or above , along with some dark frames, you might get closer to what you are after?
I have the luxury of a full frame DSLR, so a 50mm lens really is a 50mm lens, not a 75mm. I can just about get away with a 28mm lens and 25 second exposures at ISO 800 before trails become a major problem.
PS, with DeepSkyStacker, ALWAYS shoot RAW images. It makes it so much easier
