Thread started 23 Aug 2010 (Monday) 15:09
HELP!! ND filter stuck to Lee adaptor ring!
Hknivers
Aug 23, 2010 15:09 |  #1
I screwed my Hoya ND8 on to the lens, then I screwed my Lee wide angle adaptor ring on to the ND filter... Now the adaptor ring is completely stuck to the ND8. Any tips? I tried using something we call "plumper pliers" here in Norway, but it didn't work. I don't care about the ND filter, I just need the adaptor ring!
all help is appreciated!
Cheers
HÃ¥kon
Gear: 5DC with Ee-D+RRS L-plate. 17-40mm f/4L. 70-200 f/4L, Nifty Fifty. 430 EX II. Feisol CT-3442R & RRS BH-40 Pro II. Lee Filters and Heliopan Pola. F-Stop Gear Tilopa BC
http://www.hakoniverse​n.com/ (external link)
baccaruda
Aug 23, 2010 15:19 |  #2
Try running them under hot or cold water for a minute; they might expand/contract at different rates and make them easier to separate. Or maybe harder :p
Good luck.
kinghong1970
Aug 23, 2010 15:21 |  #3
i use 2 jar openers working with each other...
seems to do the trick... works up to a 77mm filter.
Albert the Clumsy Ape
GEAR | FEEDBACK | REVIEW | KING OF GREENE STREET (external link) | FS: Gitzo GT1550T, Photoclam PC30N
Hknivers
Aug 23, 2010 15:36 |  #4
kinghong1970 wrote in post #10773435 (external link)
What kind of jar openers?
PS: I tried hot/cold water...no dice. :P
kinghong1970
Aug 23, 2010 15:50 |  #5
Hknivers wrote in post #10773526 (external link)
i purchased a pair of these... (external link)
doctordare
Aug 23, 2010 17:37 |  #6
That looks like a good idea. Years ago, when we all used thin leather or plastic camera straps, the common advice was to wrap a strap around each filter (or adaptor) and then use them as a grip to turn the filters. This just looks like the modern version of using a camera strap around each filter, and would give some more leverage.
CameraBuff
Aug 23, 2010 18:18 |  #7
When my 77mm cpl got stuck on my 67mm adapter ring I used two fat rubber bands one wrapped around the filter and one around the adapter. Now I have several rubber bands in my bag. Worked great.
Sony A7r, Sony 16-35 f4, Canon 1d3, Canon 70-200 f4L, Sigma 150-600 contemporary, G1X, Lee filter holder and gnd's, Singh-Ray reverse gnd
rtiangha
Aug 23, 2010 19:02 |  #8
In keeping with the same idea as using two objects to increase torque, I love these plastic lens filter wrenches; they work really well too:
http://www.the-digital-picture.com …Filter-Wrench-Review.aspx (external link)
Of course, rubber bands are great in a pinch as well.
My Gear List
Items for Sale: My Sigma 50-500mm F4.5-6.3 APO DG OS HSM - CANON Mount, Tamron AF18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO - CANON Mount.
Hknivers
Aug 24, 2010 01:45 |  #9
I got it off....finally! Had to use a vise (or vice?) we had in our forklift garage at work, but it came off. The ND is in the bin now, but I don't care...it's easy to get a new one here, the adaptor rings has to be ordered from England and takes forever.
PS: The problem I had was that I use a Lee wide angle adaptor ring. It screws on the lens in such a way that it kinda wraps backwards over the lens to avoid vignetting when attaching the filter rig. When I then screwed it onto the ND filter the ND filter was kinda cradled within the adaptorring in such a way that when you looked at them from the side, only about half a millimeter of the filter threads on the ND was visible. That meant using lid openers and such wasn't possible, that's only doable of you have two filters attached to each other or similar. But luckily we had the right tools in our terminal here.
Anyways: Thanks for all the good suggestions! Really appreciate it. :)
3,480 views & 0 likes for this thread, 6 members have posted to it.
2826 guests, 173 members online
