Thread started 23 Aug 2010 (Monday) 15:10
Ferry and pleasure boat
match14
Aug 23, 2010 15:10 |  #1
Hi all it is about time I posted up some picture so I'll start wiht just one of critique.
HTTP response: 403 | MIME changed to 'application/xml'
David
500px (external link)
Gear
pixelmangler
Aug 23, 2010 15:48 |  #2
match14 wrote in post #10773375 (external link)
You may want to try posting the image again - It is not showing up here and following your IMG link in your post produces this message:
AccessDeniedRequest has expired
if you keep on doing what you have been doing, you're going to keep on getting the same result
match14
Aug 24, 2010 02:42 |  #3
Fixed link
David
Gear
JoYork
Aug 24, 2010 03:40 |  #4
I like the pastel shades in the sky, it gives the photograph a peaceful mood. I think the photograph might benefit from cropping away the bottom 1/4 of the image - there is a lot of water there with nothing happening. A crop would also place the boat closer to the bottom third of the image, which ought to result in a more pleasing composition.
Jo
kouman
Aug 24, 2010 07:29 |  #5
what jo said. crop away the extra water and it will look better.
5D mark ii | Sigma 85 f1.4 | 17-40 f4L YN--468 | 2x YN-560 | Einstein AB1600 | Kacey 22" BDWebsite (external link) Flickr (external link)
Feedback 1
Feedback 2
pixelmangler
Aug 24, 2010 08:17 as a reply to  @ kouman's post |  #6
Following Jo's words, I cropped some of the water in the foreground and a small amount of sky, for the reason that there was a lot of sky not adding to the composition. I moved the boat away from the centre of the frame and adjusted the histogram sliders. I moved the highlight slider left until it just touched the edge of the histogram and I moved the midtone slider to the right to add a a little more depth of tone. I think that there is a little too much green in the water but that can be adjusted to suit your tastes.
JoYork
Aug 24, 2010 09:54 |  #7
Nice work, pixelmangler, looks much better cropped down and tweaked.
Jo
pixelmangler
Aug 24, 2010 10:09 |  #8
JoYork wrote in post #10778276 (external link)
Thanks Jo. I should have rotated the image to stop the water flowing uphill. :oops:
MJF830
Joined Jun 2010
Aug 24, 2010 10:25 |  #9
Boat looks alittle green, but i think its probably this crappy work laptop or im getting sea sick. Here is my try.
IMAGE: http://i876.photobucket.com/albums/ab330/mjf830/example2.jpg
Mike
Canon 7D / Canon Xti / Canon Rebel X 35mm /Canon 70-200mm f/4 L / Canon 28-135mm is usm / Canon 50mm 1.8 mk ii / Canon 18-55mm / Canon 35-80 mm / Kodak 80-210mm EF mount / 70-300 P.O.S. / Vivtar 383 / Tamarac Aero 75 /
DAMphyne
"the more I post, the less accurate..."
Joined Feb 2003
Aug 24, 2010 11:01 |  #10
^ Much better.
Starting to look good now.
I'd be interested in seeing the OP's next best try.
David
Digital set me free
"Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute.";)
www.damphyne.com (external link)
jetcode
Aug 24, 2010 13:05 |  #11
bannedPermanently
Here's a slightly different rendering. I isolated the 4 elements for local contrast adjustment and hue and saturation for the sky and water. There is a green cast in the original and it's still an overcast day.
MJF830
Joined Jun 2010
Aug 24, 2010 14:33 |  #12
nice jetcode it looks alot sharper now with the better contrast
Mike
match14
Aug 24, 2010 15:00 as a reply to  @ jetcode's post |  #13
Thanks everyone I appreciate the comments. I have decided it look much better cropped and that yes there was a colour cast on the picture. I have re done the picture cropped and white balance adjusted and have toned down the sky a bit.
David
Gear
match14
Aug 24, 2010 15:12 |  #14
Mind you I think I prefer this.
David
Gear
2,406 views & 0 likes for this thread, 7 members have posted to it.
915 guests, 118 members online
