Thread started 23 Aug 2010 (Monday) 15:27
YN-460 II mini input hack
css7493
Aug 23, 2010 15:27 |  #1
I searched high and low on the forums and google, does anyone know a good reference to a 'how to' on hacking the 460 ii's to have a mini jack? Id rather do that for 4: yn-460's than buy 4 $25-$30 hotshoe adapters.
Gear
btmlinedan
Aug 23, 2010 16:00 |  #2
you can reference this thread : hard wire the + and - to the feet of the shoe on the internal parts. you can either make a male plug come out or use a female plug from radioshack
https://photography-on-the.net …?t=916511&highl​ight=420ez
*dan l *Flickr (external link) l *cars: dkfx Photography (external link) l weddings: Blue Martini Photography (external link) l YN622C tranceiver review (external link)
css7493
Aug 24, 2010 00:06 as a reply to  @ btmlinedan's post |  #3
nice thread, thanks for sharing it. Any tips on more specifically what I would be looking to connect with the wires for a mini input? Whats a way to differentiate + from - on the wires with the plug?
Gear
css7493
Aug 24, 2010 17:23 as a reply to  @ css7493's post |  #4
I'm trying to find if there is a thread somewhere on POTN that is as in depth as this one: https://photography-on-the.net/forum/showthre​ad.php?t=256447
more or less, if anyone else has already done the legwork for modding a yn460 ii
Gear
lazer-jock
Don't mess
Aug 25, 2010 08:51 |  #5
I just did the mod last night to 4x 460-II's. I had one where the optical slave stopped working afterward. I think that the thin little wires that go to it were pinched (in half since they're that thin) while reassembling it. However, I just followed the connection scheme here (external link), and made sure to put everything back where it came from while reassembling without too much trouble.
I'm off lining my cage with newspaper.
My Gear List
dsvilko
Aug 25, 2010 09:48 as a reply to  @ lazer-jock's post |  #6
There is also another, much less invasive (though not so neat) method of adding a sync port. This is actually what I first did on my YN460. What you do is just unscrew the flash foot, drill a small hole on the one side of the flash foot, soldier a wire to the hotshoe contacts and pull it through the drilled hole. Then put a 2.5/3.5mm connector on the wire that is now sticking out of your flash. That way you do not need to open the flash casing. It's extremely easy to break one (or both) of the small plastic 'feet' that hold the casing together (I broke one and I was extremely careful to avoid just that) when opening the casing. It's not such a big deal as I was able to superglue it back in place but the casing does not feels as solid as it used to.
1000d | 18-55 | 50mm 1.8 | 55-250mm | reversed 50mm f2.8 Zeiss + 50mm f2.8 as additional macro lens, $10 macro tubes | DIY robotic macro rail (external link) | YN-460, YN-460II | Blazzeo PT-04 triggers
https://photography-on-the.net/forum/showthre​ad.php?t=731733
css7493
Aug 25, 2010 15:43 |  #7
lazer-jock wrote in post #10784787 (external link)
... I just followed the connection scheme here (external link)
Finally! Exactly what I was looking for. Thanks!
Gear
lazer-jock
Don't mess
Aug 25, 2010 15:55 |  #8
css7493 wrote in post #10787159 (external link)
Glad to help...
My Gear List
3,020 views & 0 likes for this thread
Latest registered member is ArcticRose
622 guests, 180 members online
