escapehtml wrote:
I hate to ask this, but PS is required? That doesn't seem right to me. I never use PS for my photos unless I want a dramatic change or something for my art work. I really like 'untouched' photos for my personal enjoyment.
PS is suggested and you will get more out of your camera with it. You can , however, turn up the in-camera sharpness if you want more of a point-and-shoot feel. To do this make sure you are using the "creative zone" modes like P, Tv, Av, or M and then go to the menus. Under parameters, select either parameter 1 which boosts sharpness, contrast and saturation up a notch or go to set 1 and select them however you want. Even with sharpness, saturation and contrast turned all the way up you still won't get the over-sharpened, over-saturated and very contrasty effect you get with your point-and-shoot. These are great to show off on your computer slide show but don't suffer much work in PS or for making photo-realistic prints. It is much better to sharpen with more control in photoshop. Then you can sharpen just enough to bring out the effect you want and no more. Even then, you don't need the full photoshop, even though it is a deal at I believe $275 when you buy the 20D. You can also use PS Elements 3 which is also a fine program and a real bargain at like $75. You have to get in the habit of creating a work-flow for your images, however. You can't just shoot-and-show like you could with your point-and-shoot. However if you take the time it goes like this: shoot-sort-process-and say "Wow, I took that shot?!?". Hope that helps a little. Remember that the 20D is a hobbyist camera not a snapshot camera, but the hobby can be really rewarding!
-- Scott.
p.s. The kit lens is a fine lens especially at the wide end and especially stopped down a bit. Most people have trouble with it at 50mm, not at 18. Play with it a bit before you spend more money. If you can't get good results, come back here with some test shots and the EXIF information (the in-camera settings attached to each image) and folks here will help you out.
6dii, 70D, 20D and POTN strap, 24-105/4.0L, 100 Macro/2.8L, 50/1.4, 100-400L, 70-200/4.0L, EF-S 10-22, M42: Super Tak 135/3.5, Pentacon 135/2.8, SMC 55/2.0
