Thread started 25 Aug 2010 (Wednesday) 19:57
I took several shots like this and now want to use Deep Sky Stacker
kezug
Aug 25, 2010 19:57 |  #1
I took several 20-30 second exposures RAW (cant recall exact, but all were the same) of this image and now want to pass them through DSS.
I dont know what dark, flat, bias, dark flat means. I just have all of these.
Can I still pass this through DSS for a better "stacked" image?
IMAGE: http://i302.photobucket.com/albums/nn84/kezug/Hobby%20Shots/IMG_7645.jpg
Camera's: 70D, G12 | Len's: 18-135mm IS STM, 55-250mm IS STM, 50mm f/1.8 II | Photos:flickr (external link)
martyn_bannister
Aug 26, 2010 02:23 |  #2
Hi Kezug,
I'm wasn't sure what they are either, so I wrote a little text file to sort of explain it to myself. I have used this workflow and DSS accepts all the files. Whether they have the desired effect or not is debateable, since the weather has been appalling and I have only had one chance to use it. Results were inconclusive. Anyway, for what it's worth, it's HERE (external link). If it's wrong I hope someone more knowledgable can correct me.
Adrena1in
Aug 26, 2010 13:36 |  #3
Run 'em through DSS and see what you get, it won't hurt, and it'll probably give you a slightly better overall image.
Dark files simply help cancel out noise and hot pixels. By its definition a dark file should be 100% black, but it won't be...there'll be noisy pixels, and it's these that are removed from the final image. Or something like that.
Flat files help with vignetting, where the corners of an image can appear a bit darker. (I myself notice it more on shots with a telephoto lens set to maximum focal length.)
Don't really know myself what Bias frames are!
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
kezug
Aug 26, 2010 21:01 |  #4
martyn_bannister wrote in post #10790543 (external link)
Hi Kezug,
Thanks...that seems like a lot of information and work too.
martyn_bannister
Aug 27, 2010 01:37 |  #5
kezug wrote in post #10796664 (external link)
Sounds like a lot but when I actually did it, it wasn't too bad after all. Keeping count of what you are doing if you intersperse the dark frames would be a bit of a pain, but you don't have to do that, you can shoot them after the session if you like.
A.S.I.G.N. ­ Observatory
...For the future of mankind
Gallery: 15 photos
Aug 27, 2010 07:55 |  #6
My Tutorial (external link) may help.
Baz.
Builds By Baz website http://www.buildsbybaz​.com (external link)
mtbdudex
Gallery: 35 photos
Aug 27, 2010 13:15 |  #7
A.S.I.G.N. Observatory wrote in post #10799007 (external link)
Baz.
+1, Baz's tutorial helped get me up to speed, spend 15 min with it, then open up DSS and also read it's FAQ help file.
Note: Keep this in mind for your event planning:
Some of the added shots need to be taken with camera/sensor immediately following your shooting session to capture the temp affects to hot/cold pixels, plus some also need same focus/aperture/speed (ex: dark frames are same as light frames except use the cap). If you forget taking them then you can't afterward, too late, still process them but won't get full benefit of DSS abilities.
welcome to DSS.
Mike R, P.E. ...iMac 27"(i7), iPad2, iPhone14Pro, AppleTV4K, MacBook
Canon: Body R5, lens RF 24-105mm L F4, RF 100-500mm f/4.5-7.1L, 1.4 TC, EF 70-200 L f2.8 IS II / TC 1.4x 2x
FEISOL tripod CT-3441S + CB-40D Ball Head
My top 10 in Astrophotography. . .DIY acoustic panels (external link) . . APOD Aug-5-2011 (external link)
3,563 views & 0 likes for this thread, 5 members have posted to it.
1050 guests, 107 members online
