Thread started 30 Aug 2010 (Monday) 14:23
70-200 F4 IS focus problem
hdd
Joined Aug 2004
Aug 30, 2010 14:23 |  #1
im new to this lens so maybe im doing something wrong. Ive been using the 24-105 lens before this one and I can get the lens pretty much right on top of a flower or etc im focusing on. The 70-200 I have to be a good 4-5ft away to autofocus correct?
When im at this distance it seems to focus about 1-2inches behind what I actaully have centered to focus on. Im using the center spot focus dot on the 50d if that matters but it seems to ovbershoot the focus.
here is a example
http://www.delanofarms​.net/077a.JPG (external link)
I was focused on the flower and bee but it picked the buds behind the flower which are tac sharp. Ive tried a couple quick shots on distance objects and focusing is ok. Is this just a issue up close on objects? Do I need to send the lens back to get calibrated?
Canon 50D/S5 IS
Canon 24-105 & 70-200mm IS f/4 "L" - Canon 50mm f1.8 - Sigma 17-70mm f2.8 - 430EX
Capture By Design Photography (external link)
markol
Aug 30, 2010 14:41 |  #2
You will definitely need to be further away. The minimum focusing distance is 3.9 feet on that lens. That said it should be able to focus very quickly on the selected focus point. What body are you shooting with?
www.borrowlenses.com (external link)
hdd
Joined Aug 2004
Aug 30, 2010 14:49 |  #3
using the 50d... i backed up and everything seems fine there. I wanted to make sure it wasnt something wrong with the lens. Seems the farther away with that lens the better it does. Its very quick also.
Canon 50D/S5 IS
MNGUYEN
Aug 30, 2010 14:49 |  #4
Have you tried to micro adjust the lens on the 50D?
5D/30D 35L 85L 135L 17-40L 24-105L 70-200L 4IS
Full Gear and Feedback
hdd
Joined Aug 2004
Aug 30, 2010 15:10 |  #5
i tried but it looks like its in perfect focus untill i get it on the pc scrren to edit.
Canon 50D/S5 IS
malla1962
Joined Jul 2004
Aug 30, 2010 15:36 as a reply to  @ hdd's post |  #6
Do you have the limiter set to 1.2m?
hdd
Joined Aug 2004
Aug 30, 2010 15:56 |  #7
Yes I had it on 3 but for close up I moved it to 1.2
it could have be just me... 90% of the shots look great. These were the first shots so ill test it more this week. Still has warranty anyway.
I havent done any micro adjustments within the camera and etc... if needed I may need to fine tune that.
Canon 50D/S5 IS
hdd
Joined Aug 2004
Aug 30, 2010 15:59 |  #8
http://delanophotograp​hy.zenfolio.com/img/s1​0/v17/p107904320-4.jpg (external link)
another shot as I backed about 6ft away.... everything seems fine at that distance. I really need a macro lens also since you cant have the best of both worlds
Canon 50D/S5 IS
hdd
Joined Aug 2004
Aug 30, 2010 17:12 |  #9
I tried the microadjustments on the 50d but never really saw any difference when I focused on some letters about 5ft away. So I put it back on 0 in the middle. Maybe I was just to close so it focused on the rear of the flowers. I had the camera set on f5.6 also
Canon 50D/S5 IS
2,718 views & 0 likes for this thread
Latest registered member is vini81
797 guests, 259 members online
