FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 30 Aug 2010 (Monday) 18:01
First HDR, need advice
IdiotsAbound
Aug 30, 2010 18:01 |  #1
Did some playing around with Oloneo and I am amazed how easy and realistic it is.
However, I need some advice as I am not that experienced with Photoshop. As shown in the crop, I have some red noise bleeding from the light. How do I fix that in PP using CS3? Can it be controlled in Oloneo or must it be done in Photoshop?
TIA!
Taken with Canon XSI using the 18-55mm IS kit lense, Sherpa Pro CF tripod and wired remote.
AEB used at ISO 100 @ f/8 27mm
canon2311
Sep 21, 2010 12:54 |  #2
In Photoshop try this.
Go to Enhance -> Adjust Lighting -> Brightness/ Contrast - have a bit of a tweak there.
Also you can try Enhance -> Adjust Color -> Adjust Color Curves.
Using either of these adjust the options until you make it abit darker. I had a go and it improved the overall picture straight away. The tarmac is quite light and therefore distracts as the area is quite big.
Darken it all abit, and the picture will look alot better - hope this helps.
983 views & 0 likes for this thread, 2 members have posted to it.
1354 guests, 189 members online
