Thread started 31 Aug 2010 (Tuesday) 14:17
Lens Hood EF 400 2.8 - Detail photo wanted
thyme
Aug 31, 2010 14:17 |  #1
I am the happy owner of a EF 400mm 2.8 II, unfortunately the lens hood (ET-161BII) has been repaired and does not work perfectly.
I have just purchased an original locker mechanism, and it would therefore be helpfull if somebody can provide detail pictures of the original locker mechanism.
It would be extremely helpful to get pictures from outside and inside - assembled and dissembled.
The attached pictures shows my own modified version.
Regards
Per
EOS 5D2
EF 400mm 2.8, EF 50mm 2.5 macro, EF 100mm 2.8 IS macro, EF 24-105 IS USM
Sigma 150mm Macro, 50mm 2.8 macro
Carl Zeiss 100mm 2.0 Macro
580EX, MR14EX, MT24EX
Manfrotto 055CXPRO3, 488RC4, 393
ScatterCr
Sep 01, 2010 14:49 |  #2
Here are some photos of the locker mechanism from my ET161B-II. The lens hood has been modified from its original configuration. The original threads stripped out of the mechanism. IMHO Canon did not use the proper screw size for the mechanism.
I repaired it by very carefully removing what was left of the remaining threads with a pin vise & drill. Then, I redrilled all of the way through with a tap drill and cut new oversized threads with a tap. The original screw holes in the hood also had to be drilled oversize for the new larger screws.
Use plenty of Aluminum Cutting Oil to keep the drills & tap from seizing & breaking and go slowly. It is important to make sure that everything is square so the screws are not side loaded when they are tightened. The screws, drills, & tap necessary to make this modification are available at Ace Hardware.
Erik
Gear | flickr (external link)
ScatterCr
Sep 01, 2010 14:59 |  #3
Here's a side view. Good luck with your repair.
Erik
thyme
Sep 02, 2010 09:26 as a reply to  @ ScatterCr's post |  #4
Hi ScatterCrSport
Thank you for the nice pictures -very helpful :-)
Anyone who can provide 100% original shots?
Regards
Per
EOS 5D2
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Sep 02, 2010 10:58 |  #5
Nice work Scatter,.
these locking mechanism were/are a pretty poor weak point, especially on lenses of this era.
On the 200mm f/1.8 I used to own, it all still worked,. but just barely, and even in a functioning set up,. one could see how dreadful the design was and how likely it was to fail. Your solution seems to be a step in the right direction over the original Canon.
CDS' HOT LINKS
ChunkyDA
Gallery: 17 photos
Dec 17, 2015 22:05 |  #6
I know this is an old thread but just in case someone else does a search... Just picked up a used 300 2.8 from Adorama and the hood lock mechanism was broken. I took it apart and seems the small E-ring clip had failed and wedged itself in the slot. I am trying to get in touch with the Adorama sales guy to see if they want to swap it out but I am sending it to CPS for a clean & check. If CPS does a free fix all will be right with the world.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/12/3/LQ_764924.jpg
Image hosted by forum (764924) © ChunkyDA [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/12/3/LQ_764925.jpg
Image hosted by forum (764925) © ChunkyDA [SHARE LINK]
Dave
Support Search and Rescue, Get Lost (external link)
Gear list and some feedback
HelenOster
That's me!
Dec 20, 2015 06:15 |  #7
ChunkyDA wrote in post #17823128 (external link)
If you have no luck, please email me directly: Helen@adorama.com
johnf3f
Dec 20, 2015 18:30 |  #8
Hosted photo: posted by ChunkyDA in
./showthread.php?p=178​23128&i=i171932036
forum: Canon Lenses
./showthread.php?p=178​23128&i=i75493873
forum: Canon Lenses
I have seen this exact problem on my own 300 F2.8 and a couple of 500 F4 lenses. I just bought a few different size circlips on E Bay and used the one that was the best fit - much cheaper than sending it back to Canon! I don't know what circlips Canon use but they do appear to be an alloy of butter - they are the worst that I have ever seen!
Unfortunately I cannot remember which size fit best! Just try a few different ones they cost next to nothing.
Life is for living, cameras are to capture it (one day I will learn how!).
4,830 views & 0 likes for this thread, 6 members have posted to it.
1867 guests, 111 members online
