Thread started 01 Sep 2010 (Wednesday) 19:36
Ball head for DSLR Video?
By-tor
Gallery: 2207 photos
Sep 01, 2010 19:36 |  #1
I'm currently using a Manfrotto 055xprob tripod with a 488 RC2 head. I love the setup and it works very well for still shots & video, but not good for panning video.
I would like to get a good head for around $100.
Any help would be appreciated..
All the world's indeed a stage and we are merely players performers and portrayers.
cskorik
Sep 01, 2010 20:02 |  #2
Also interested in this. Anyone got some advice?
My portfolio (external link)!
DisrupTer911
Sep 01, 2010 20:53 |  #3
You either should get a leveling base and then level the QR clamp or get a video fluid head but that's way more then $100...both options are over $100...
www.vividemotionphotograph​y.comexternal link
SkipD
Joined Dec 2002
Sep 01, 2010 20:53 |  #4
A ball head is not the best choice for video work. What I would recommend that would be compatible with the 488RC2 (using the same quick release system, that is) is Manfrotto's 128RC fluid head.
The 128RC only has two axes of movement and, because of that, I use Manfrotto's 438 levelling head under my fluid head to be able to easily level the 128RC head without messing with the tripod's legs.
In reality, I use the older 3130 fluid head and 3502 levelling head but these are just old numbers for the same items as I listed above.
Skip Douglas
By-tor
Sep 01, 2010 21:00 as a reply to  @ SkipD's post |  #5
Ball head may have been the wrong words to use eh!!!
I'm going to be using my 7D and it has a built in level, but would a leveling head still be better?
I would love to be able to use the same QR plates that I have now...
SkipD
Joined Dec 2002
Sep 01, 2010 21:07 |  #6
By-tor wrote in post #10833235 (external link)
Look up the stuff I suggested. You will see what the leveling head is all about. It simply goes between the tripod leg set and whatever head you mount on it. The camera is held by the head that's on top of the levelling head.
The purpose of the levelling head is not necessarily to measure what's level but to be able to easily adjust the position of the head (which holds the camera) so its base is level.
The 128RC, as I said above, uses the same RC2 quick release system as the 488RC2. You can switch heads on the tripod but leave the same QR (Quick Release) plates on the camera and lenses.
Skip Douglas
By-tor
Sep 01, 2010 21:10 |  #7
Would this leveling plate be needed if the leg set has a built in level?
I looked at that 128RC on Adorama and it may just be the one to get.
SkipD wrote in post #10833283 (external link)
SkipD
Joined Dec 2002
Sep 01, 2010 21:20 |  #8
By-tor wrote in post #10833306 (external link)
It's a royal pain in the tush to do precision level adjustment of a tripod by tweaking each leg to get there. That's why the 438 Camera Leveler is so handy. It allows you to set up the tripod roughly level and then in a VERY short time you can level the tripod's head with the 438 Camera Leveler.
Skip Douglas
By-tor
Sep 01, 2010 22:33 |  #9
Understand... Thanks
SkipD wrote in post #10833378 (external link)
7,236 views & 0 likes for this thread, 4 members have posted to it.
2527 guests, 170 members online
