Thread started 02 Sep 2010 (Thursday) 00:08
Shooting artwork(paintings)
buurin
Sep 02, 2010 00:08 |  #1
A friend wants me to shoot her paintings.
I believe they are on canvas and are not behind glass...
Any links to tips? I've googled and only found some pretty basic stuff.
I'm curious about ALL aspects.. lighting, lenses(focal length), setup, etc..
B
30D ● 5D ● Canon 24-70/2.8L
Canon 17-40/4.0L Canon 50/1.4 ● Canon 100mm/2.8 Macro ● 2xVivitar 285HVs ● 430EX ● Cybersync Flash Triggers ● AB800 ● AB400 ● Vagabond II
Karl ­ Johnston
Sep 02, 2010 04:50 |  #2
A lot of painters opt to have their work scanned rather than photographed.
Adventurous Photographer, Writer (external link) & Wedding Photographer (external link)
SkipD
Joined Dec 2002
Sep 02, 2010 05:12 |  #3
buurin wrote in post #10834545 (external link)
You should use a lens that lets you stay several feet from the painting and that has very little pincushion or barrel distortion. Your 100mm lens should do just fine.
You will want to do some very serious color control. You need to make sure that your monitor is properly calibrated (using both hardware - a colorimeter - and software) before attempting such a project. You will need at least a known neutral reference card and, preferably something like a Color Checker card (external link) to get your images displaying the proper colors.
What is your background with lighting? What do you have for lighting modifiers?
Skip Douglas
neilwood32
Sep 02, 2010 07:10 |  #4
Ensure you are shooting at 90 deg to the painting.
Yes it is possible to alter the shape in PP but it does reduce the quality - better to capture i t right first time.
As Skip has said, WB is critical so do a custom WB. Even correcting in RAW might not get a 100% accurate WB.
Lightingwise, try to make sure the lighting is as even as possible. If need be use a diffuser to reduce any bright spots.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Sep 02, 2010 08:56 |  #5
How to photograph your art. (external link)
Photographing my Artwork
How to Photograph Art (external link)
Copying old portraits
20droger
Sep 02, 2010 09:21 as a reply to  @ PhotosGuy's post |  #6
1. Use a macro lens of 100mm or longer. That's a real macro lens, not just some lens that has "Macro" on it.
2. Mount the camera absolutely perpendicular to the subject both vertically and horizontally.
3. Distance the camera so that the subject almost but not quite fills the frame. Crop later.
4. Use two equidistant and identical diffuse light sources at 45° to the subject at its centerline.
5. Use custom white balance.
crobs808
Sep 03, 2010 15:06 |  #7
Only use FF bodies to shoot artwork. It does the artist an injustice to use anything else.
1. Use FF
2. Use L glass
3. Shoot at 90 degrees (perpendicular to artwork)
4. Shoot sections/quadrants, then stick together for higher final resolution
5DII | 28-135mm IS USM | 50mm II | HVX200
No trees were harmed in the creation of this post; however, a large number of electrons were terribly inconvenienced.
buurin
Sep 03, 2010 16:12 |  #8
crobs808 wrote in post #10844921 (external link)
1. Use FF
2. Use L glass
Interesting feedback.. Do you really think there would be a discernable difference between my crop(30D) & prime(100f2) vs FF & L-glass?
I would think under such controlled circumstances the FF/L doesn't have much advantage.
If you were to shoot in quadrants how would you reliably move the camera around?
B
itzcryptic
Sep 03, 2010 19:03 |  #9
The advice about shooting only with FF is just silly IMO.
Fast ­ Fredy
Sep 03, 2010 20:14 |  #10
buurin wrote in post #10845309 (external link)
The recommendation of using a real 1:1 macro lens is good. Macro lenses are designed to be sharp from "edge to edge". I have the 100f2 and it is good, but a macro lens will out perform it.
buurin
Sep 03, 2010 21:41 |  #11
Fast Fredy wrote in post #10846462 (external link)
Ive heard macro lenses tend to not perform well (or at least optimally) outside of the close focus distances which they are designed for...
Ive never used a true dedicated macro lens so I have no idea.
B
20droger
Sep 03, 2010 23:32 |  #12
buurin wrote in post #10846794 (external link)
Not true. Macros work supremely well out to infinity.
A true macro lens is a prime lens (there is no such thing as a zoom macro lens) that has a couple of things going for it that non-macro lenses lack: an extremely flat plane of focus; and a long focus ring travel.
A macro lens has an extremely flat plane of focus because one of its primary uses is as a copy lens. This, of course, makes it ideal for shooting artwork, which is essentially copying, where a sharp corner-to-corner focus is required.
A macro lens has a long focus ring travel because it is usually focused manually at distances where the depth of field is extremely shallow and focusing is critical. Again, this makes it ideal for shooting flat artwork, as the focus can easily be adjusted exactly on. Ideally, a split prism focus screen would be used.
Beware, however, of non-macro lenses labeled "Macro." This is purely a marketing ploy, and many lenses are so labeled. Many such lenses are truly optically atrocious.
yogestee
Sep 04, 2010 00:20 as a reply to  @ 20droger's post |  #13
Most "normal" lenses camera weren't designed to shoot two dimensional subjects like artwork, documents or brickwalls.. Normal lenses have too much of a fall off in resolution from edge to edge, corner to corner,, and in many cases curvature of field and barrel and/or pin cushion distortion.. Zoom lenses are worse.. This kind of photography is reserved for flat field lenses which are rare and very expensive.. The best option for artwork photography are macro lenses..
Jurgen
cfortner
Sep 04, 2010 00:42 |  #14
I'd suggest exposure bracketing your shots so you can have the opportunity to create hdr photos as well.
buurin
Sep 04, 2010 02:08 |  #15
cfortner wrote in post #10847596 (external link)
For this particular shoot I am trying to represent the artwork accurately.. My lack of experience with HDR(photomatix) makes it difficult for me to create realistic looking photos.
Also, I can't imagine the dynamic range of the artwork would require or benfit from HDR. I could be wrong.
Sounds like I am going to go with a macro lens. I am thinking the 100/f2.8 which I can rent locally.
What about lighting? I have two alienbees(ab800, ab400) and a large softbox(27"x55") & a large octobox(47") as well as 3 speedlights & unbrella.
I was thinkign just using the bee's and the octo+softbox @ 45 degrees left and right.
Thanks for all the help
B
6,015 views & 0 likes for this thread, 16 members have posted to it.
1459 guests, 131 members online
