vid1900 Senior Member 557 posts Joined Feb 2010 More info | Sep 03, 2010 19:46 | #1 No bragging list - I just rent whatever the job requires.
Sep 03, 2010 19:47 | #2 Will this be the death of CF? No bragging list - I just rent whatever the job requires.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Sep 03, 2010 21:24 | #3 Not likely. It merely demonstrates the strength of the CF standard. This marks, what, the 4th SD standard, while there's only one CF standard (which has been around even longer than the oldest SD specification) and that's getting faster and faster as memory speeds improve, but the cards are backward compatible with older devices (absent the separate issue of FAT limits). With SD, you can't take a new "standard" card and use it in a device that doesn't support the "new standard". Jon
Sep 03, 2010 23:23 | #4 sweet. Maybe thats why canon put sd in the 60d? https://500px.com/chriskennedydotphoto
HappySnapper90 Cream of the Crop 5,145 posts Likes: 3 Joined Aug 2008 Location: Cleveland, Ohio More info | Sep 08, 2010 09:22 | #6 NeverFollow wrote in post #10847275 sweet. Maybe thats why canon put sd in the 60d? Exactly why. Canon and nikon knew what was coming. The d7000 is rumored to have 2 SD card slots.
Flores Goldmember 1,179 posts Likes: 2 Joined May 2010 Location: TEXAS More info | Sep 08, 2010 09:30 | #7 think video. an HD video that runs as long as two batteries in a grip is going to be dozens of gigs.(20 minutes = ~4gigs)
jacobsen1 Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Sep 08, 2010 11:40 | #8 actually, 10~12min = 4gig... My Gear List
banpreso Goldmember 2,176 posts Likes: 4 Joined Feb 2009 Location: Socal More info | Sep 08, 2010 12:06 | #9 Flores wrote in post #10871224 think video. an HD video that runs as long as two batteries in a grip is going to be dozens of gigs.(20 minutes = ~4gigs) also consider: video studios need cheap and fast ways to move raw footage around. high speed SD cards in the T size 'solve' that issue nicely. you can always run a battery cable to an external power source
Brianbar Senior Member 397 posts Joined Feb 2004 Location: Canada More info | Sep 08, 2010 18:43 | #10 Jon wrote in post #10846725 Not likely. It merely demonstrates the strength of the CF standard. This marks, what, the 4th SD standard, while there's only one CF standard (which has been around even longer than the oldest SD specification) and that's getting faster and faster as memory speeds improve, but the cards are backward compatible with older devices (absent the separate issue of FAT limits). With SD, you can't take a new "standard" card and use it in a device that doesn't support the "new standard". +1 on this, as said it's unlikely that the new SD cards will fit into currant cameras using SDHC or SDXC, or current card readers, another marketing con.
Sep 08, 2010 23:33 | #11 Permanent banNeverFollow wrote in post #10847275 sweet. Maybe thats why canon put sd in the 60d? no thats not why, because 60d will not support the extra speed.
Flores Goldmember 1,179 posts Likes: 2 Joined May 2010 Location: TEXAS More info | Sep 09, 2010 15:03 | #12 ah, basing mine on 24fps HD, not 30.
CameraAddict Member 98 posts Joined Feb 2010 More info | Sep 09, 2010 22:02 | #13 Whatever you do, don't pay the early adopter premium and buy this card thinking it will give you speed in your current camera. None of the current, nor just announced cameras, support the speed. 50D, 5D Mark II, 24-105, 70-200 IS, 100-400, 100 f/2.8, 10-22, 70-300 Non-L (for sale), 28-135, 50 f/1.8, Kenko tubes, 430 EX II, Wacom Bamboo Pen/Touch, LR3, PS5
Cougar548 Senior Member 348 posts Likes: 3 Joined May 2007 Location: Kansas City More info | Sep 10, 2010 17:52 | #14 Brianbar wrote in post #10874348 Whats wrong with the CF card anyways? +1
| Latest registered member is johntmyers418 991 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
