Thread started 05 Sep 2010 (Sunday) 07:53
Time to admit defeat?
hania
Sep 05, 2010 07:53 |  #1
Imac.
I have a Lacie 500GB external drive I have been using for my Time Machine Backups.
Suddenly it fails to backup - saying there is a problem with the disc.
I repair the disk and all is ok for a day when the same happens again on Time Machine backup.
The repair fails this time so I spend 20 hours writing 'zero' to the disc.
I then run 'verify' and it says all is ok.
I then try Time machine again - same result as before - again if fails to backup.
I run ' repair : on 'verify' I get "invalid node structure", and currently is is repairing (very slowly for an empty drive - it estimates 2 mins but has been going for at least 15) .
Is it time to admit defeat and get a new drive?
rioni
Sep 05, 2010 08:58 |  #2
Perhaps. I'd try:
- Testing it on another machine to see if there is a problem there.
- If not, trying on another USB connection on your same machine.
- Writing a large file to the drive independent of the backup process. Does that fail?
- Any odd sounds like clicking coming from the drive? If so, it's going to die soon.
- Most important, if you feel the drive is failing, "back up" all backup data ASAP.
hania
Sep 05, 2010 13:43 |  #3
rioni wrote in post #10853371 (external link)
Perhaps. I'd try:
have written 57G of 93 G - still writing ok so far- another 2 hours to go.
update : wrote 93G ok.
Will try again.
update: seemed ok - but, when I do : get info: I apparently have 111G on disc - when I open it there is nothing.
Tried repairing disc and I get : error : can't unmount disc!
shall try erasing again
tim
Light Bringer
Sep 06, 2010 04:53 |  #4
I'd toss the disk as soon as I got the first error. Disks are cheap. Data's priceless.
hania
Sep 06, 2010 06:32 |  #5
tim wrote in post #10857858 (external link)
quite - still getting error - so shall scrap
jasonlitka
Sep 07, 2010 21:04 |  #6
Dead on. One error = RMA if in warranty or trash if it isn't.
Jason Litka | Utter Ramblings (external link)
7D, Rebel T2i, 24-105mm f/4L IS USM, 70-300mm f/4-5.6L, 100mm f/2.8L Macro IS USM, 24mm f/1.4L II USM, 10-22mm USM, 17-85mm IS USM, Sigma 30mm f/1.4, Speedlite 270EX, Panasonic Lumix DMC-LX5, Fuji X100s on order.
kfreels
Sep 07, 2010 23:40 as a reply to  @ jasonlitka's post |  #7
Don't trash it till you try it on another machine. I've seem many people do this when the real problem is a faulty motherboard power supply sending irregular voltage to the USB header causing write errors on the disk. Power supply should be your first suspect with "intermittent" problems and definitely the place to start if the disk works on another machine. Of course if you re-format on a different machine and try to use it on that alternate machine and it fails, it is the disk - or the cord - or the AC adapter. Eliminate all of those possibilities before you toss it.
I am serious....and don't call me Shirley.
Canon 7D and a bunch of other stuff
hania
Sep 08, 2010 03:59 |  #8
kfreels wrote in post #10869386 (external link)
Am currently having it checked out. thanks for all the replies
yes - drive dead!
1,615 views & 0 likes for this thread
Latest registered member is socrbob
967 guests, 322 members online
