Thread started 05 Sep 2010 (Sunday) 08:32
No flash, low light events - Best approach for newbie?
drmaxx
Gallery: 41 photos
Sep 05, 2010 08:32 |  #1
Last week I tried to cover a low light indoor event. The usual thing with almost no light in the audience and a soft spot on the speaker and a slide show.
I got a EOS XTi, 50mm f/1.4 and a 15-85 mm f3.5-something lenses (image stabilisation). No flash allowed.
The talks were boring - so I had some time to play around and find a good approach to shoot some decent pictures.
* I figured quite rapidly that the automatic mode (P) is quite useless. The XTi does not go automatically above ISO800 in this mode. Does anybody has a good explanation why this is?
* The best results were achieved with setting the speed to 1/30 and the ISO to 1600 (the maximum) and shoot away.
Would anybody recommend an other approach? What would you experts do in such a situation to achieve the best results (except from buying faster glass and a new camera:lol:).
Donate if you love POTN
Peor
Sep 05, 2010 08:39 |  #2
I think you have covered the three variables
- ISO (you can use 3200 or even 6400 on newer sensors)
- Speed (as long as the people stay still you should be able to go down even further if you have something to lean the kamera to)
- Lens (if you would go with a 50/1.8 that would give you 2 more steps)
If you go high ISO, Canons Digital Photoshop Professional software will be able to reduce the noise even further.
PeO.
Canon 6D 24-105/4L, 70-200/2.8LII, Sigma 12-24, SIgma 50/1.4 Art
SilentShutter
Joined Jun 2010
Sep 05, 2010 08:42 |  #3
Highest ISO you can, your f # should be fairly low to help gather as much light as possible, and then find the highest shutter speed that works for the settings.
It's very tricky to get the hang of low light events, but a non-moving speaker shouldn't be too difficult. Concerts or sports in low light are much harder because of the movement.
Canon PowerShot SX40HS
Steady hands, an open eye, and a (hopefully) empty SD card
My flickr page (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Sep 05, 2010 08:53 |  #4
That's the simplest solution.
If I could have used a tripod, maybe try some lower ISO & shutter speeds, & wait for the speaker to pause & hold still.
DStanic
Sep 05, 2010 10:30 |  #5
How about being ABLE to shoot ISO3200 with your XTi ? ;)
https://photography-on-the.net/forum/showthre​ad.php?t=742806
Also I'd add to your list to shoot in RAW, you will be better able to deal with noise when pushing your camera to the limit, JPG will limit how much you can do.
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
Sorarse
Sep 05, 2010 10:58 |  #6
Highest ISO that you are happy to use before noise becomes a problem, widest aperture lens is capable of, providing resulting narrow dof doesn't cause problems. Keep your fingers crossed that the subsequent shutter speed is fast enough to prevent motion blur.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
tonylong
...winded
Gallery: 60 photos
Sep 05, 2010 22:47 |  #7
I assume you were using your 50 f/1.4, which should be a fantastic low light lens. What aperture were you shooting at?
I'd start at ISO 1600, and try Av at f/1.4 and see what kind of shutter speed you get and take it from there. Don't wait 'till your next actual event, though, turn the lights "low on" at home in the night and do some tests.
The P mode is simply using a max of ISO 800 because it's safe, as in less risk of horrible noise. But if you can get a good exposure at 1600 (avoid trying to boost shadows in pp) then you might be pleasantly surprised at the outcome.
Tony
spiralspirit
Sep 05, 2010 23:21 |  #8
someone mentioned a tripod if possible, but if not a monopod can help quite a bit with some practice. basically anything that will reduce shaking or allow your shutter to speed up.
canon 1dmk2* Canon XSi * Sigma 24-70 f/2.8 EX DG * Canon 17-40mm f/4L * Sigma 70-200 f/2.8 EX * Canon 50mm f/1.8 *
drmaxx
Gallery: 41 photos
Sep 06, 2010 03:09 |  #9
Thanks a lot for all these interesting replies.
tonylong wrote in post #10856854 (external link)
This is probably the main lesson I learned. However, this was one of the moments where I took my camera along to do some practice shots and to see how to deal with these kind of situations. And then it turns out that I am the only one with a decent camera and the organizer is asking me to take some pictures:lol:.
Actually, I used both lenses and both with the widest aperture (1.4 and 3.5). With the 50 mm lens I got some decent pictures, after quite some post processing (I am still working on the best way to do that). However, I really like the somewhat underexposed pictures of the 3.5 aperture. Not much post processing (not much light to work with) but they capture the atmosphere of the evening quite accurately (see example below).
The tripod idea is good - need to add that to my wish list.
tonylong
...winded
Gallery: 60 photos
Sep 06, 2010 03:35 |  #10
drmaxx wrote in post #10857655 (external link)
Yeah, there's nothing wrong with having some shadow areas, but rather than switch to the slower lens, I would use that leeway in ways that will enhance your image qualities. For instance, your 50mm f/1.4 will sharpen up a bit at, say, f/1.8 or f/2. And, if you increase your shutter speed a bit that will help to get over motion blur a bit. And, if you can still stand a bit less exposed, lowering your ISO will tend to lower your image noise.
So, rather than just using your slower lens to get some underexposure, try utilizing your other functions to actually improve the output as you lower the exposure a tad.
Just my humble advice...:)!
A tripod is good if you can manage one in the venue -- have one around or in the car, and if conditions allow, sure! Or, someone mentioned a monopod -- some conditions are too busy/crowded to manage a tripod, some managers will frown upon them for liability considerations (understandable in a crowded club with "imbibing" patrons, but a monopod can be less "out there"!
Tony
2,568 views & 0 likes for this thread, 8 members have posted to it.
1130 guests, 166 members online
