Greetings ...
I've had the G6 since it first came out and love the camera. In recent weeks, the LCD had started to act up ... occasionally freezing the image when taking a picture, then fading to a white screen, then fading to an inverse (or "negative") of the frozen image before fading to black. Typically, switching modes or depressing the shutter button would fix it.
Today, the camera started up with a white LCD screen and nothing can get the image back. The problem seems to be limited to only when the LCD is folded out 180 degrees to the left of the camera body, which is how I typically use it. If it is swiveled 90 degrees (perpendicular) to the camera body or if the LCD is rotated and folded back behind the camera (so the screen is viewable underneath the viewfinder), it seems to work fine.
I'm thinking/hoping it is a loose wire or connection in the LCD screen as I'd hate to get rid of the camera. Can someone point me to instructions or provide some details as to what I would be looking for ... and where?
Thanks in advance,
Jason
