No more carrying around collections of N-grad filters. Simply dial in the desired ISO values, select the gradient type (soft-edge, sharp-edge, direction), and the camera automatically adjusts the ISO sensitivity across the sensor. Too bright sky? Dial in 2 or 3-stops lower ISO value at the top of the sensor and problem solved! How long will it take to implement such feature?
