jdizzle wrote in post #10866051
Nice work Kody. Are these falls easily accessible.
Thanks Julian. Being out there and only being able to use the 10-stop on the 70-200 made me REALLY want the Big Stopper even more than I already do! See below for accessibility.
squirl033 wrote in post #10866062
the first one is Ruby Falls. I don't know if the second one has a name, or is just considered an extension of Ruby, before the river enters the Washington Cascades which are right downstream... either way, i like the composition of #2. Narada Falls is actually about 160', though it looks taller from the base of the falls. you were fortunate to get it a low-flow... it's much more graceful than in spring, when it's just a roaring torrent. i don't think i've ever seen the rocks at Christine Falls look that red - is that because of the long exposure from the 10-stop ND filter?
Thanks for all the info. I thought there was a sign near Ruby Falls but I couldn't remember. I need to get better at taking notes. I didn't read the signs about Narada either. hehe I was just making a best-guess. As far as the color of the rocks I would guess it's a combination of the lighting and the longer exposures? I used cloudy WB which can tend to warm things a bit. When using the 10-stop ND which I used on the shot of Christine Falls it certainly gave the images a magenta color-cast which I did my best to fix in PP.
My PP is very simple though. I import, I run a "Landscape" preset in LR3, add the Lens Profile, adjust the exposure/brightness/contrast and sometimes add a little clarity. That's it. I always attempt to replicate the colors in the image as I saw them.
fr4nk wrote in post #10866069
Excellent captures.
Nicely done all the way.
Thanks Frank!
squirl033 wrote in post #10866079
very. the first one, Ruby Falls, is less than 20 yards from the road, and #2 is just a few yards downstream. Narada Falls has a trail that takes you about 200 yards, if that, from the parking lot to the viewpoint on the other side of the river. the viewpoint for Christine Falls is also within 25 yards or so of the parking area.
As Squirl says, all of these are readily accessible from the road with most of them having pull-outs near the falls for parking. Some of the shots I took were from the road where there are bridges going over the water. The Narada Falls trail is listed as .1 miles.
It's downhill to a landing area you can see from the parking lot. It's very easy unless you've worked your legs out the night before. lol
Here's another shot taken from the bridge (the road) over Christine Falls. (Very accessible).
| HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
