I need some opinion regarding wide angle lenses. I want to buy one but I'm not an expert. I appreciate all your opinion. Not too cheap but not too expensive. For hobby and recreation but atleast semi pro to pro entry level. Thanks everyone!
litratista Senior Member 608 posts Likes: 196 Joined Sep 2010 More info | Sep 08, 2010 22:41 | #1 I need some opinion regarding wide angle lenses. I want to buy one but I'm not an expert. I appreciate all your opinion. Not too cheap but not too expensive. For hobby and recreation but atleast semi pro to pro entry level. Thanks everyone! 5D Mark III, 5D mark II, EF 50mm f/1.2L USM, EF 70-200mm f/2.8L IS II USM, Tokina 11-16mm F2.8, EF 24mm-105mm f/4.0L IS USM
KayakPhotos Goldmember More info | Sep 08, 2010 22:59 | #2 This is going to take some research on your part. There are A LOT of good wide angle lenses that you can use with your camera. If you are really wanting a WIDE angle, then you will need to go with an ultrawide. Make sure that you get an ultrawide for crop sensor rather than full-frame. On crop UWA is 8-12 range. On FF, it is around 16 or 17 generally. Just a thought from Daniel
thank you for your detailed assistance good sir! 5D Mark III, 5D mark II, EF 50mm f/1.2L USM, EF 70-200mm f/2.8L IS II USM, Tokina 11-16mm F2.8, EF 24mm-105mm f/4.0L IS USM
hisownhero Member 201 posts Joined Nov 2009 Location: Rochester, NY More info | Sep 09, 2010 07:22 | #4 Check this out: Juza Nature Canon 5D - Canon 20-35mm f/3.5-4.5 USM - Canon 50mm f/1.4 USM
Sep 09, 2010 07:37 | #5 Will do! Thanks. 5D Mark III, 5D mark II, EF 50mm f/1.2L USM, EF 70-200mm f/2.8L IS II USM, Tokina 11-16mm F2.8, EF 24mm-105mm f/4.0L IS USM
Alex_Venom Goldmember 1,624 posts Likes: 1 Joined Nov 2008 More info | Sep 09, 2010 08:07 | #6 The flare on the Tokina is really annoying. You have to learn how to deal with it... Photography is about GEAR and not talent or practice. Practice won't make you a better photographer. Expensive equipment will. =D
Sep 09, 2010 08:47 | #7 LOVE my tokina 11-16, fantastic lens. 6D, Sigma 24mm f1.4 art, sigma 85 f1.4 art
KayakPhotos Goldmember More info | Your welcome. There is also a new Sigma 8-16 lens that came out recently. It seems to perform very well, but does not take screw in type filters. A modified filter holder can be made, but it is a pain and the filters you would have to use with it are kind of expensive. Just a thought from Daniel
Patrick.TeSeng Member 57 posts Joined Apr 2007 Location: Manila, Philippines More info | Sep 09, 2010 09:25 | #9 I have Canon's 10-22. It's an excellent lens, rivaling my L lens in sharpness (not surprising as it has L-quality optics). Very good build quality (it's not made of metal but it's very well-built) and it's light.
hieu1004 Goldmember 3,579 posts Likes: 4 Joined Jul 2010 Location: Seattle More info | Sep 09, 2010 09:48 | #10 I was in the same boat about a month ago and I did extensive research when choosing my UWA lens. It came down to the Sigma 10-20, Canon 10-22, and Tokina 11-16. Since I do a lot of indoor shooting, I needed the 2.8, so the Tokina was the clear winner. I felt like the build was better than the others as well. So far, the 11-16mm has been nothing short of amazing.
kylyo Senior Member 570 posts Likes: 4 Joined Oct 2009 Location: Seattle, WA More info | Get the Tokina 11-16, you won't regret it! If you plan on doing any indoor/lower light stuff it is the only choice. It is sharp! I couldn't be happier with it. Flare is a little annoying but can be handled with good technique! 5d III | Canon 16-35L II | Canon 35L | Canon 70-200 II |
Fangs404 Member 240 posts Joined Apr 2009 Location: Iowa City, IA More info | Sep 09, 2010 12:47 | #12 40Driggs wrote in post #10877845 Your welcome. There is also a new Sigma 8-16 lens that came out recently. It seems to perform very well, but does not take screw in type filters. A modified filter holder can be made, but it is a pain and the filters you would have to use with it are kind of expensive. This is what I'd look at. It's supposed to be incredibly sharp, too. Canon 50D
ccookdo Senior Member 391 posts Joined Sep 2005 More info | Sep 09, 2010 15:45 | #13 I bought a Tokina 11-16 and compared it to the Canon. I did not care for the very short range of 11-16mm focal length. I might as well just get a prime. The longer 10-22 range for the Canon makes it much more useable, and it was every bit as sharp as the Tok.
Sep 09, 2010 19:26 | #14 I have the Tamron 10-24, its nice plus now they have 100 rebate cartoontruck IMAGE LINK: http://www.flickr.com …/13637337@N05/4961863964/ caddy Canon R10 , Canon RF 100-400
markol Senior Member 841 posts Joined Jun 2007 Location: San Francisco More info | Sep 09, 2010 20:23 | #15 Our customers rent the Tokina 11-16 and the Canon 10-22 the most. You can always rent them too and see which one you like but you will be happy with either.
| Latest registered member is EBiffany 1605 guests, 102 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
