It started off with me trying to check the accuracy of the metering of my old Pentax ME Super, which I thought was suspect. I decided to use my Canon EOS 3 and EOS 400 to compare against the ME Super.
All cameras were set to the same ISO. All were in aperture priority mode and all set to f/8. I had a 50mm lens on the Pentax, EF 50 1.8 on the EOS 400 and a EF 24-105L set to 50mm on the EOS 3. The Pentax and the EOS 400 gave very similar shutter speeds but the EOS 3 was was indicating a slower shutter speed... about a full stop slower.
I then started swapping the two Canon bodies and lenses and it seems that regardless of what body is used, the 24-105L always resulted in a slower shutter speed for the same conditions. Should I be worried? Is there a simple explanation?
