Thread started 11 Sep 2010 (Saturday) 12:15
Higher MP is bad?
RTPVid
Sep 11, 2010 12:15 |  #1
I was reading reviews of the T2i and I came across this...
There are a number of disadvantages associated with higher pixel density sensors. One important consideration is that you will want to invest in a higher end quality lens that can support the sensor's increased resolution capability. The simple rule is that if you invest in a higher-resolution camera you need a lens that offers sufficient resolving power, which generally means spending more...
Now, I come from the film days, and this argument seems completely bogus to me. Back in the day, it was always a challenge for the lens manufacturers to produce lenses with the resolving power to get the most out of fine-grain film, whether Kodachrome 25, Pan-X B&W or even Tri-X. No one criticized the film because to get the most out of it, you may need to upgrade your lens. No one said that grainier film was better because it did not expose the flaws in the less expensive lenses people might own. They placed the criticism where it belonged... on the lens.
What has changed? Has the fact that we now depend on the camera / lens manufacturer to also produce the "film" (sensor) resulted the the manufacturers producing sub-standard lenses since the sensor can't see the difference anyway?
It is fair to criticize the technology trade-offs, for example, the same review stated this:
Other issues related to high pixel density include; lower dynamic range, reduced high ISO performance, diffraction issues, and increased possibility of camera shake.
I don't know about the camera shake deal... this reviewer seemed unreasonably biased against Canon throughout, and this seems like a real reach for something to criticize. But, the points about dynamic range and high ISO performance may be correct, I don't know. I do know the same issues faced film manufacturers. Typically, fine-grained film did not perform well when pushed to high ISO (I still want to say ASA... so you know I'm old) ratings, resulting typically in contrasty and grainy images.
But, the initial point... a 12 MP sensor is better (and, hence, the Nikon D90's sensor is better) because it lets you get away with a cheaper lens compared with an 18 MP sensor... seems like the criticism is misplaced... that is the fault of the lens, not the sensor. And, in fact, what this really means is the camera's sensor is limiting the benefit you might get in the future should you choose to upgrade your lens.
Tom
District_History_Fan
Sep 11, 2010 12:18 |  #2
Higher MP bad = internet BS.
Get a current Canon dSLR, feed it great glass, and prepare to be amazed at the detail in the resulting files. You can smile at the fact that Canon does this at equal noise levels to the lower res Noinks (save the D3s).
www.ericmcferrin.smugm​ug.com (external link)
Joe ­ Ravenstein
Sep 11, 2010 12:23 |  #3
Lenses are not the place to save money, if you feel you need to scrimp bucks skip the filters. Acquire lenses equal to the sensors IQ to obtain the best results .
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
hpulley
Sep 11, 2010 12:29 |  #4
Everything it says is true, it is the conclusion that it means high MP = bad that is wrong. It is true that higher resolution sensors will show poor lenses, poor focus, poor camera holding technique, etc. more than low resolution sensors when magnified by the same amount. When printed to the same size it may not show it more but at 100% you'll see more shake and focus error at 18MP than 6MP.
Just like with fine grained film if your lens isn't up to the task then it is a waste, you might as well use low resolving film if your lens or technique are poor.
flickr (external link) 1DIIN 40D 1NRS 650 1.4xII EF12II Pel8 50f1.8I 28-80II 17-40L 24-70L 100-400L 177A 199A OC-E3 RS-80N3
DC ­ Fan
Sep 11, 2010 12:31 as a reply to  @ District_History_Fan's post |  #5
Actual pictures from a T2i as referenced in the review:
The increased pixel count of the T2i over previous cameras in the same Canon line causes no problems. The T2i actually has better high ISO performance over previous cameras...
...so there's no disadvantage there. (ISO 3200 example above.)
Lowner
"I'm the original idiot"
Sep 11, 2010 12:39 as a reply to  @ DC Fan's post |  #6
Higher pixel counts do expose weaknesses in a number of areas, optics are just one. And thats why Canon and others are now engaged in updating their line up.
The more megapixels the better because it forces manufacturers to address the problems it exposes. The problem has been that in the race for more MP, other issues have been put to one side and are only now being taken seriously.
I am looking forward to seeing the first 100mp camera in the next year or so. May not be Canon but so what.
Richard
mike_d
Sep 11, 2010 12:49 |  #7
The big issue I see with high pixel density (ie. smaller sensor sites) is that diffraction shows itself at bigger apertures. That's physics and I don't see how they can get around that. Light's a wave. Sorry.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Sep 11, 2010 12:50 as a reply to  @ Lowner's post |  #8
It's larger magnifications that causes "problems" with camera shake, faults in lenses and so on.
As long as we keep on magnifying our images more and more, they will of course look more blurred due to shake, for example. That is the same as using a longer focal length. More magnification = more impact from shake.
So why do we keep on magnifying more? Because an enormous amount of digital camera users seem to think that it's pixels that are interesting, not pictures. So wee keep on blowing up images to 100% matching between camera pixels and screen pixels, disregarding that the whole picture has grown out of the room we have our computers in. Except for some who frequently post at dpreview; they first sharpen the same image as much as possible three times in succession, then look at it at 400%.
This of course means that every fault there may be in the image is more and more visible to us. So we keep on complaining about the wind in our hair, disregarding that we are going 250 km/h now, not 50 km/h as we did a few years ago.
No matter what kind of lens you have, it will benefit from a sensor of higher resolution. An inferior lens will not benefit that much, but it will benefit. From a picture point of view, increased resolution is always good.
There may be limitations in the electronics used to implement this resolution, but it's there the compromise should be done, not because we use the EF-S 18-55 mm f/3.5-5.6 II on our 18 Megapixel 7D.
Anders
picturecrazy
soft-hearted weenie-boy
Sep 11, 2010 12:51 |  #9
As mentioned, there are definitely disadvantages to having a high MP count on a similarly sized sensor.
But theoretically, that means there are also ADVANTAGES.
The sole advantage in a higher MP count is to obtain more DETAIL, for more enlargement and cropping options.
The problem is, most lenses are not capable of delivering the detail that these densely packed sensors want. So you basically get pictures that take up a lot more hard drive space, all while they don't give you any more detail than a smaller 12mp file.
I'm guessing THAT'S why he says more MP = bad.
There may be a new batch of lenses that come out that can deliver the detail the 7D/T2i is starving for.
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
Lowner
Sep 11, 2010 12:58 |  #10
"The big issue I see with high pixel density (ie. smaller sensor sites) is that diffraction shows itself at bigger apertures. That's physics and I don't see how they can get around that. Light's a wave. Sorry".
Thats what used to be said about the speed of light, now doubts are being openly aired. I believe that it will either be resolved, or the "problem" will be circumvented in some other way.
Science does not fully understand wave dynamics in water, never mind light. So any categoric statement saying something is impossible should be taken with a pinch of salt. What it really means is "we don't know how to do it right now".
Richard
Mark2Mark
Sep 11, 2010 13:07 as a reply to  @ mike_d's post |  #11
District_History_Fan wrote in post #10890121 (external link)
Absolutely. The fact that the 21MP Canon 5D2 has similar high-ISO noise to the 12MP D700 is hugely impressive. I'd really love to see Canon coming out with a couple versions of the 1DS4, say, 25+MP for the detailed landscapes, and a super-high-ISO beast with 18MP on a full frame for concerts etc. I know it's possible.
DC Fan wrote in post #10890156 (external link)
WOW, that made me smile. :D
Lowner wrote in post #10890177 (external link)
.... and a good thing it is too. I have the 70-200 mk I, but I now lust after the 70-200 mk II, and I can't wait to see the 24-70 mk II. I hope the improvement there is similar to the 70-200 update.
Gear
HKGuns
Gallery: 45 photos
Sep 11, 2010 13:16 |  #12
The only disadvantage I see with higher MP count is increased disk space requirements. All the other stuff is just internet posturing by people who don't actually take pictures.
dave ­ kadolph
"Fix the cigarette lighter"
Location: West Michigan--166.33 miles to the Cook County courthouse
Sep 11, 2010 13:33 as a reply to  @ HKGuns's post |  #13
As with all things there is no free lunch--higher MP sensors have advantages and disadvantages.
Putting them in consumer grade bodies is questionable marketing--the typical buyer is more likely to buy cheap lenses such as the 70-300III than a piece of high quality glass--and be disappoined with the results they get.
Middle age is when you can finally afford the things that a young man could truly enjoy.
Tools of the trade
apersson850
Gallery: 35 photos
Sep 11, 2010 13:42 as a reply to  @ HKGuns's post |  #14
The comments above about low-class lenses and diffraction are both wrong. Well, the comments aren't, but the conclusions drawn from them.
All lenses benefit from higher resolution. Inferior lenses just not that much.
Images taken at all apertures benefit from higher resolution. Small apertures just not that much.
Diffraction is exactly the same with lower resolutions, you just don't know it. As long as the sensor size is the same, so is the effect of diffraction. A picture taken at f/32 with an 8 MP 30D suffers from the same degree of diffraction as if it was taken with a 7D. This doesn't make the picture from the 7D inferior, just not as superior as it would be if both pictures were taken at f/2.8.
Anders
1duser
Sep 11, 2010 13:43 |  #15
The number of megapixels doesn't tell what kind of resolution the sensor is really capable of capturing. There are so many other factors. In compact cameras higher mp is definitely bad these days. It's only needed for marketing.
5Dc | Nex-5N | Lumia 1020
8,826 views & 0 likes for this thread, 23 members have posted to it.
Higher MP is bad?
1380 guests, 135 members online
