Maximono wrote in post #10891636
Working it out I figured it must be my technique as the 400mm x 1.6 crop would equal 640mm and the 500mm and 1.3 crop of the 1Dmk3/4 equals 650mm.
But now however from working things out and briefly reading over things I believe that what is true is that crop factor will help to fill the image or "magnifiy" onto the frame what i see with the 400mm and the 7D, but because this guy is using a 500mm lens the subject is bigger in the frame already and is "magnified" less by the 1.3 crop but this doesn't matter as much as the 500mm is obviously bringing out much more subject detail with that extra 100mm, than I'm getting with the extra crop of the 7D, as it's really just cropping in the field of view and not actually magnifying detail of distant subjects at all really.
It appears to me that you don't really understand the "crop factor" basics, so I will try to help.
In your first paragraph above, you are calculating what's known as "35mm equivalent focal lengths". This is fine, as long as you understand what's happening. What you are doing in both cases (APS-C and APS-H calculations) is determining what focal lengths would give you the same field (angle) of view on a 35mm film format camera (which includes several so-called "full-frame" DSLRs).
Your second paragraph, however, is where I get the idea that you don't understand the facts. There is no "magnification" going on when you use different format cameras. The term format, by the way, refers to the size of the film frame or digital sensor in a camera.
Please read the following carefully. It is a bit long, but should help you understand what the "crop factor" is all about. Then, I'll get to the points you need answered.
The "crop factor" is a reference number that relates to the difference in film or sensor size (known as the camera's "format") between two cameras like the Canon 7D and a 35mm film (or a so-called "full-frame" digital) camera. Let me list the facts:
35mm film cameras and so-called "full frame" DSLRs have a film frame or sensor size of approximately 24mm X 36mm, while the Canon 7D has an APS-C sized sensor, measuring approximately 14.9mm X 22.3mm. The other Canon APS-C format cameras - starting with the D30 in the year 2000 and progressing through all of the "digital Rebel" xxxD series, the xxD series, and today's 7D - all have sensors that are sized similar to that in the 7D.
When camera manufacturers started designing digital SLRs (DSLRs), they decided that the DSLR bodies should be about the same physical size and configuration as their 35mm film SLRs. For that reason, they concluded that they could use the line of lenses they already had for their 35mm SLRs on the new DSLRs.
All lenses designed for 35mm cameras project an image circle onto the film that covers a 24mm X 36mm rectangle. The 35mm camera records the portion of that image circle that is defined by the opening behind the shutter for the film (24mm X 36mm in size). A digital SLR with an APS-C sized sensor only records the smaller area (approximately 14.9mm X 22.3mm) of the image circle projected by the same lens.
When you put a 100mm lens on a 35mm film camera and make a photograph, then put the same lens on a DSLR such as the Canon 7D and make a similar photograph - same subject, same position for the camera, and same focal length - and then enlarge both photographs to the same size print (4 X 6 inches, for example), it will appear as though the photo from the Canon 7D was taken with a longer lens. That is because the image recorded by the Canon 7D was of a SMALLER PORTION of the image circle projected by the lens - cropped, if you will - compared to the image recorded by the 35mm camera.
The special lenses for the Canon 7D (and other Canon APS-C cameras starting with the 300D - the first Digital Rebel) are called the EF-S series. These project a smaller image circle, making the lenses less expensive to design and produce in wide-angle and extreme wide-angle formats. The EF-S lenses also project deeper into the camera than the EF specification allows (the "S" referring to "Short back focus), allowing for less expensive wide-angle lens designs. However, an EF-S lens set to 40mm will produce the exact same image as an EF lens set to 40mm if both lenses are used on the same APS-C format body and both lenses are focused at "infinity". Focal length is focal length, period.
Now to the primary point that I want to make: NOTHING about lens EVER CHANGES when you put it on different format cameras. Focal length never changes. Aperture range never changes. The only thing that would change is the apparent field of view, and that change is not a function of the lens but it is a function of the size of the sensor or film that will record the image.
The "crop factor" calculation for "35mm equivalent focal length" has only one valid use. That is for comparing lenses used on two different format cameras.
Here's one common example: Joe took a photo of Mount Rushmore with a 35mm camera from a particular place using a 200mm lens. You want to replicate that photo with your Canon 7D. What focal length do you need to do that from the same location that he took his photo? Divide the 200mm by 1.6 and you get the answer - 125mm.
Here's another popular example: Mary Sue has been using a Canon SX120 IS point-n-shoot camera and is wanting to use a Canon 50D DSLR. She is, of course, interested in what focal lengths she would need to keep the versatility of the SX120 camera's 10X super-zoom lens. The SX120 lens is actually a 6.0mm to 60.0mm lens, but the advertising also shows the "35mm equivalent" focal length range as 36mm to 360mm. To know the focal lengths needed for the 50D, merely divide the "35mm equivalent" values by 1.6. In other words, Mary Sue would need 22.5mm on the short end and 225mm on the long end for the 50D to have the same field (angle) of view coverage as her SX120 IS camera.
The "crop factor" is NOTHING MORE than a REFERENCE between the two camera formats that lets you compare the field of view of particular focal lengths between the two formats.
The "crop factor" (as related to using lenses essentially designed for 35mm SLR cameras) is always given assuming that the 35mm format (24mm X 36mm) is the reference master. Something to realize, though, is that the 35mm film format is not, never has been, and never will be the master" format against which all other camera formats are referenced. It is simply the format of the cameras that have also evolved into today's commonly used digital SLRs.
Now that you have the basics, there are a couple of things that need to be added into your thinking about the combinations of camera formats and lens focal lengths.
One thing you need to consider is the resolution of each digital camera's sensor. That relates to the number of pixels in the camera's image files. In your comparison of the 7D and the 1D MkIV, you need to know the relative sizes of the sensors.
- The sensor length or width in the 1D MkIV is 1.25 times the size (in each direction) of the sensor in the 7D.
- The area of the 1D MkIV sensor is 1.56 times the area of the 7D sensor (1.25 squared).
- The number of pixels in a 7D file is 17,915,904.
- The number of pixels in a 1D MkIV file is 15,980,544.
Using the "crop factor" calculations to get the "35mm equivalent focal lengths" for each lens/camera combination:
- 400mm on the 7D gives the same field of view as a 644mm lens on a 35mm film camera (400 x 1.61).
- 500mm on the 1D MkIV gives the same field of view as a 645mm lens on a 35mm film camera (500 x 1.29).
Since the resolution (pixel count in the image) of the 7D is greater than that of the 1D MkIV and the field of view of both rigs (7D/400, 1D/500) is the same (proved by the "crop factor" calculations), the best combination would be the 7D/400.
