sbgrace wrote:
Ok, I think I figured out two possibilities. First, I turned the flash off because I didn't like how it washed things out. The camera compensated with a lower shutter speed...blurry pictures. I guess I will look into getting a flash attachment and maybe a diffuser. Then the autofucus was/is having issues with focusing on one or the other of the boys. I guess I'll mess with the AV value so I get a better depth of field. Maybe first try just taking off the autofocus. Finally, I think this camera just can't take motion in the subjects. I am going to try messing with the TV setting for that maybe??
Rachelle
Dear Rachelle,
Please forgive me if I misinterpret what you are saying about Tv and Av. You should realize that these two modes are mutually exclusive - i.e., you cannot set values in Av and then set values in Tv and expect both of your settings to be maintained. You must pick one of the modes and do everything within that mode. That being the case, you must decide upon having the greater depth of field OR the faster shutter speed - the two parameters work against one another. That is, greater depth of field requires stopping down the lens more while a faster shutter speed will require opening up the lens more. You can't have your cake and eat it, too!
In my opinion you should probably use mode Tv, set the shutter speed for 1/125 or 1/250 (whatever it takes to stop the motion) and live with the fact that the lens will automatically go to f/2.0 (wide open) AND the auto ISO setting will probably go right to ISO 400, which will cause some degradation of the image in the shadows due to noise.
Good luck!
