Thread started 12 Sep 2010 (Sunday) 17:39
7D triggering two speedlights Q
glockamole
Sep 12, 2010 17:39 |  #1
I would like to trigger two 430ex flashes with my 7D and expose using ETTL. Haven't bought the second flash yet but can get one used for under $200. Now the only way this appears to work is by setting the on-camera flash to ETTL (which I could trigger using manual setting at 1/64 or whatever the smallest setting is). Thus, even if I give it a low ratio, I will still have some head-on light. Is this the wrong way to approach this? The second flash would also come in handy for my XTi my wife is starting to get into. Thanks.
The ­ Loft ­ Studios
Sep 12, 2010 18:05 |  #2
You can achieve this in Manual Mode.....
If you put you 7D's flash at it's lowest manual power rating (let's say 1/64 power) and set the other two flashes at what ever Manual Power Rating you want them to be (say 1/2 power on one and 1/8 power on the other), then if the other two flash are in range of the 7D's preflash, then all 3 flashes will fire..... But you'll have to seriously chimp on your exposure or use a light meter.....(LOL, then again, I just realized that that isn't ETTL) it's just simply wireless flash using Canon's Wireless IR Technology. So, to answer your question, I don't think that you can set your Master Flash (7D on camera flash in your case) to manual, and still have the Slave Flashes do ETTL. But you can do it the opposite way. You can have your Master Flash set to ETTL and have your Slave Flashes set to Manual Power Flash.
MARK
Titus213
Sep 12, 2010 18:24 |  #3
Do it in ETTL and turn off the on board flash. That way it should just act as a master for the slaves.
Dave
Perspiring photographer.
glockamole
Sep 12, 2010 22:05 |  #4
Thanks guys. But I really want to use the speeedlights on ETTL. They won't work unless the camera flash is on ETTL. I could go manual in a studio, but I really want the auto exposure outdoors on the move.
Titus213
Sep 12, 2010 22:25 |  #5
glockamole wrote in post #10897374 (external link)
Unfortunately your need/desire is the direct reverse of the best capability of the ETTL wireless system. It works best indoors in a studio. Bright light reduces the effectiveness/reliabil​ity.
But you do understand you can do this with the 7D and not have the pop up flash contribute to the exposure, right?
Dave
SnlpeR
Sep 13, 2010 01:23 as a reply to  @ Titus213's post |  #6
just set the wireless func. to just fire the speedlights
i really like using the7d wireless feature in manual mode tho
no more needing to go to each light and setting the power
everything can be done on camera!
glockamole
Sep 13, 2010 08:30 |  #7
Thanks, guys. I guess I didn't understand how the on-camera flash can be set to not contribute to the exposure. With only one speedlight, I have to set a ratio that includes the on-camera flash. But looking at the manual, it looks like a second speedlight allows you to exclude the on-camera flash.
PacAce
Joined Feb 2003
Sep 13, 2010 08:57 |  #8
glockamole wrote in post #10899104 (external link)
A 2nd external flash is not really necessary to exclude the built-in flash. Take a look at page 120 of your 7D manual ("Fully Automatic Shoting with One External Speedlite") and especially note step 5 which tells you how to set the camera so that the internal flash is NOT used for exposure.
...Leo
glockamole
Sep 13, 2010 09:40 |  #9
PacAce wrote in post #10899223 (external link)
Thanks alot, PacAce. I got it working. I had read those pages a few times. I'm a bit slow. So I think I'm going to pick up another 430EX.
pcj
Sep 13, 2010 10:01 |  #10
Just to confirm what everyone else is saying - the 7D popup flash can be set to not contribute to the final pic. To be clear - it will STILL FIRE - but this is happening *before* the exposure, and it is only there to communicate to the other lights. The human eye doesn't register it as multiple flashes - we only see one.
Two 430exII's can be triggered in this manner, in ETTL mode. I do it all the time with my 580exII and 430exII.
7D (gripped) | GoPro Hero HD | Canon 70-200mm f/4 L | Tamron 28-75mm f/2.8 | 40mm f/2.8 | 85mm f/1.8 | 28mm f/1.8 | 3 * 600EX-RT - All gear
http://www.rt2photo.co​m (external link)
http://www.facebook.co​m/rt2photo (external link)
PacAce
Joined Feb 2003
Sep 13, 2010 13:12 |  #11
pcj wrote in post #10899551 (external link)
To be technically accurate, the command flash will also flash when the shutter curtain is open so the command flash going off in the picture may be noticeable and will contribute, however slightly, to the overall exposure even if the master is disabled. An easy way to confirm this is to take your camera into the bathroom (without the slave flash) and take a picture of yourself in the mirror with all the lights off. :)
...Leo
2,828 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is Miss Understood
478 guests, 190 members online
