Thread started 14 Sep 2010 (Tuesday) 21:54
The astro bug has bitten: rookie Andromeda
Badger49456
Sep 14, 2010 21:54 |  #1
I read the stacking tutorial over in the discussion section and wanted to give it a try. I think my first attempt went better than my second!
I already posted my first in the discussion thread. Two nights ago I used the Tamrom 28-75 f/2.8 at 75mm, f2.8, ISO1600, 13" each x 22 light frames + 23 dark:
IMAGE: http://farm5.static.flickr.com/4154/4985673376_de234ce962_z.jpg
IMAGE LINK: http://www.flickr.com/​photos/nathmath/498567​3376/  (external link)
Andromeda (external link) by Shaman Tanthew (external link), on Flickr
Last night I went out for my second attempt. This time I used the Sigma 180mm macro at f/4, ISO 1600, and 2" each to avoid trails x 575 light frames + 64 dark. With no mount, I had to keep an eye on the LCD and readjust the tripod every time Andromeda moved out of the frame, plus I used mirror-lockup because of my rickety tripod; yes, I took 575 frames manually hitting the shutter release cable, making that 575*2=1150 times I had to hit that button. Sitting out there for ~2 hours got me 19 minutes worth of exposure. :lol:
Andromeda M31 (external link) by Shaman Tanthew (external link), on Flickr
Not what I was hoping for, but the exercise in patience has me looking forward to a new tripod and perhaps something like an Astrotrac.
turkleten
Sep 14, 2010 22:13 |  #2
Nice shots! I'm learningmyself. What do you mean by "light" and "dark" frames?
7D | 50mm ƒ1.4 | 17-50 ƒ2.8
Gear | Feedback
ahPhotography
Sep 14, 2010 23:17 |  #3
I was wondering the same... what are light and dark frames. I have an answer in my head, but would rather hear it from elsewhere lol
Ashley Hanet Photography ;)
Canon 550D "it's not about the gear its knowing how to use it."
my gear.
my fanpage. (external link)
website. (external link)
Sorarse
Sep 15, 2010 02:44 |  #4
A light frame is an exposure of the stars. A dark frame is an exposure at exactly the same settings, particularly with regard to shutter speed, but with the lens cap on.
What the dark frame does is highlight hot pixels and noise generated by the long exposures used in astrophotography, which is why it is important to use the same shutter speed and preferably at the same temperature.
Stacking software used to put them all together can use the information provided by the dark frames to reduce/remove the hot pixels and noise from the light frames, resulting in a cleaner image.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
mtbdudex
Gallery: 35 photos
Sep 15, 2010 03:40 as a reply to  @ Sorarse's post |  #5
Badger49456, very nice, I'll try this with my 15-85 lens at 85mm.
Where is "SL Michigan"?
I show SE Michigan in my profile, but live by M59/US23 area, overhead is sorta dark but nearer horizon I get light pollution effects.
[edit]
M31 directly overhead (almost) 5am, I'm shooting now!
Mike R, P.E. ...iMac 27"(i7), iPad2, iPhone14Pro, AppleTV4K, MacBook
Canon: Body R5, lens RF 24-105mm L F4, RF 100-500mm f/4.5-7.1L, 1.4 TC, EF 70-200 L f2.8 IS II / TC 1.4x 2x
FEISOL tripod CT-3441S + CB-40D Ball Head
My top 10 in Astrophotography. . .DIY acoustic panels (external link) . . APOD Aug-5-2011 (external link)
Edsport
Sep 15, 2010 06:28 |  #6
Pretty good for 2 second exposures. You should be able to go longer without star trailing...
Cameras - Canon 350D, 5D
Lenses - Canon 18-55mm, 75-300mm, 50mm f/1.8, 24-105L, 24-70L
Flashes - Yongnuo YN460 II, YN468
RF-602 transmitter and 2 receivers
turkleten
Sep 15, 2010 07:28 |  #7
Sorarse wrote in post #10912191 (external link)
Thanks. That means I can create my dark frames now and stack them? lol
Gear | Feedback
mtbdudex
Gallery: 35 photos
Sep 15, 2010 08:29 as a reply to  @ turkleten's post |  #8
Badger49456;
I'll pp my shots and put into own thread, but you got me outside early this morning...so sharing in your thread.
Located M31, this is 1 of many test shots took @ 15mm trying to center it onto the frame. Centered above the peak of our home.
IMAGE: http://lh3.ggpht.com/_FqTNmgNQHz8/TJDIsHbqFpI/AAAAAAAAK5I/BoaRKgN0Ezk/s800/_MG_3742.jpg
Then as I had almost centered, went to take a shot at 50mm, this effect happened....lens creep!
That what happens when you shoot almost straight up.
Kinda cool, almost Star Trek looking...
IMAGE: http://lh5.ggpht.com/_FqTNmgNQHz8/TJDIsRCjJ8I/AAAAAAAAK5M/LvUaYkdnOV8/s800/_MG_3744.jpg
I'll do DSS and post in my own thread later....
Badger49456
Sep 15, 2010 16:34 |  #9
turkleten wrote in post #10910833 (external link)
ashleyhanetphotography wrote in post #10911210 (external link)
Thank you! And thank Sorarse for the explanation.
mtbdudex wrote in post #10912312 (external link)
[edit]
Thanks, mtb. SL is Spring Lake, on the west side of the state. There is a bit of light pollution over here with Muskegon and Grand Rapids being the biggest contributors, but it is possible to make out the Milky Way on good nights.
Edsport wrote in post #10912635 (external link)
Thanks Edsport. Even at 3 seconds I thought I saw some trailing with 180mm, but it might have ended up so negligible that I probably should have extended the exposure.
mtbdudex wrote in post #10913107 (external link)
Badger49456;
Not gonna lie, I like the effect!
mtbdudex
Gallery: 35 photos
Sep 15, 2010 20:17 as a reply to  @ Badger49456's post |  #10
small world, my sister and brother in law live in spring lake, we visit them 2 times/year.
Love the west side, yea you have more dark skies then where I live.
luigis
Sep 15, 2010 20:28 |  #11
The second shot is never going to work well, 2'' is just not enough for an untracked shot. Averaging 500 2'' shots is not the same as averaging 20 50'' shots.
The first shot is quite good, I think the background is clipped as the sky is never so dark, the WB seems to be off with a strong red cast in Andromeda and there seems to be plenty of hotpixels around. You can try with some bias/offset frames to see if that helps, just take them at the same ISO1600, lens cap on and 1/8000 speed. Maybe that helps.
Cheers
Luis
www.luisargerich.com (external link)
Landscape Photography & Astrophotography
My Awesome Gear List
mullski
Sep 21, 2010 14:16 |  #12
looks really good
Badger49456
Sep 29, 2010 17:09 |  #13
Went out again last night with the 28-75 at 2.8, 10 second exposures this time and ISO 1600. I finally got an intervalometer which makes life easier. I really need a decent tripod and a tracking mount!
IMAGE: http://farm5.static.flickr.com/4150/5037556006_b0217e8b74_z.jpg
IMAGE LINK: http://www.flickr.com/​photos/nathmath/503755​6006/  (external link)
primnumbers
Sep 30, 2010 23:41 |  #14
What software is used for stacking and can you provide a link?
Eugene Nowaczyk
Canon 40D with grip
18-55mm, 28-135mm, 50mm f1.4, 85 f1.8, 70-200mm f2.8
Sigma 50-500
430EX , 540ez (x2) TwinLink wrieless triger
turkleten
Oct 01, 2010 00:01 |  #15
primnumbers wrote in post #11012352 (external link)
I think it's Deep Space Stacker.
Here's the link for the free download for the freeware:
http://deepskystacker.​free.fr/english/index.​html (external link)
Gear | Feedback
7,522 views & 0 likes for this thread, 10 members have posted to it.
1370 guests, 188 members online
