I printed a picture from Lightroom and it came out very dull, not vibrant at all. The reds were almost non existent.
Did I miss a setting.
When I printed it from CS5 or another software the colors were great.
carshop Goldmember 1,846 posts Joined Jun 2009 Location: Ontario, Canada More info | Sep 18, 2010 04:31 | #1 I printed a picture from Lightroom and it came out very dull, not vibrant at all. The reds were almost non existent. ShawnSmugmug
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Sep 18, 2010 04:55 | #2 Possibly, Lightroom printing isn't as simple as it should be. My collection of boxes with holes
Sep 18, 2010 05:05 | #3 I was using Printer Managed ShawnSmugmug
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Sep 18, 2010 05:10 | #4 Depending on the printer, that may be the issue. Lightroom by default uses the ProPhoto colour space which some printer drivers have issues converting into their output space. My collection of boxes with holes
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Sep 18, 2010 05:22 | #5 What printer? I get perfect prints from my Epson R1900 and LR, but only since I learned a certain trick. Elie / אלי
Sep 18, 2010 05:34 | #6 Hank: Will try that, thanks. ShawnSmugmug
tonylong ...winded More info | Sep 18, 2010 12:20 | #7 Shawn, did your printer driver come with paper profiles that are, as Hank mentions, visible to Lightroom? If so, you have something to try, but some consumer ink jets don't provide profiles for external apps, in which case you'll need to adjust your final file to get the print you need when doing Printer Managed printing. Tony
Bakewell Goldmember 1,385 posts Joined Jan 2006 Location: Irvine, CA More info | Sep 18, 2010 13:18 | #8 Permanent bantzalman wrote in post #10931239 What printer? I get perfect prints from my Epson R1900 and LR, but only since I learned a certain trick. Also, is your monitor hardware calibrated? Because without that all bets are off. I need to ask you what the "trick" is...My R1900 prints with exposure a half stop too dark... Dave
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Sep 18, 2010 14:39 | #9 carshop wrote in post #10931149 When I printed it from CS5 or another software the colors were great. carshop wrote in post #10931207 I was using Printer Managed In both applications? "I think the idea of art kills creativity" - Douglas Adams
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Sep 18, 2010 15:30 | #10 Bakewell wrote in post #10932559 I need to ask you what the "trick" is...My R1900 prints with exposure a half stop too dark... No problem, although it is going to sound goofy, but it works. Set up LR to manage the printing and select the profile for your paper. So far it's normal but now comes the goofy part. Open the driver GUI, Advanced tab and ICM. If until now you have been doing the color management from LR, 'Off (no color adjustment)' should be checked. Uncheck it. ICM Mode is Driver ICM (basic) and for both the Input Profile and and the Printer Profile set exactly the same profile that you set in LR. The first part is logical because the incoming data from LR is indeed in that space, but you'd think that setting Input and Printer to the same thing would mean that no conversion will take place. But something does change in the data because now it prints lighter and pretty accurately. Elie / אלי
Bakewell Goldmember 1,385 posts Joined Jan 2006 Location: Irvine, CA More info | Sep 18, 2010 21:38 | #11 Permanent bantzalman wrote in post #10933037 No problem, although it is going to sound goofy, but it works. Set up LR to manage the printing and select the profile for your paper. So far it's normal but now comes the goofy part. Open the driver GUI, Advanced tab and ICM. If until now you have been doing the color management from LR, 'Off (no color adjustment)' should be checked. Uncheck it. ICM Mode is Driver ICM (basic) and for both the Input Profile and and the Printer Profile set exactly the same profile that you set in LR. The first part is logical because the incoming data from LR is indeed in that space, but you'd think that setting Input and Printer to the same thing would mean that no conversion will take place. But something does change in the data because now it prints lighter and pretty accurately. I learned about this here: http://www.lightroomforums.net/index.php?topic=2863.0 Thanks for the tip....glad it worked for you. I saw this thread before but it did not help. Thanks again. Dave
Sep 19, 2010 08:04 | #12 René Damkot wrote in post #10932857 In both applications? With the same settings, they should produce the same print. Then again, LR using MelissaRGB as a working space might present prioblems. Try letting the software manage colors. Will try, thanks ShawnSmugmug
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Sep 19, 2010 10:13 | #13 Bakewell wrote in post #10934525 Thanks for the tip....glad it worked for you. I saw this thread before but it did not help. Thanks again. And the problem only occurs when printing from LR? "I think the idea of art kills creativity" - Douglas Adams
Bakewell Goldmember 1,385 posts Joined Jan 2006 Location: Irvine, CA More info | Sep 19, 2010 11:44 | #14 Permanent banRené Damkot wrote in post #10936631 And the problem only occurs when printing from LR? What OS / printerdriver? Windows 7 Ultimate x64 / Epson R1900 specific from their website. Dave
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Sep 19, 2010 13:54 | #15 Are you sure the issue isn't just that your screen is too bright? "I think the idea of art kills creativity" - Douglas Adams
| Latest registered member is zachary24 1439 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
