Thread started 18 Sep 2010 (Saturday) 13:59
7D issue?? Has this happened to anyone?
rawkhopper
Sep 18, 2010 13:59 |  #1
I've had my 7D since Christmas. Over the past month I've noticed that 30% of the time when I press the shutter down part way, nothing happens. It is so frustrating. This is consistant using different lenses. I'm pretty sure that I'm going to send it to Canon on Monday but I wanted to check here.
Has anyone had this problem with their 7D?
TIA.
Canon 7D, Canon EF 70-200mm f/2.8 L IS USM , Canon EF 24-70mm f/2.8 L USM , Tamron 90 mm f2.8 Macro, Canon EF-S 10-22mm f/3.5-4.5 USM, Canon EF 40mm f/2.8 pancake, Canon EF 1.4x II teleconverter
apersson850
Gallery: 35 photos
Sep 18, 2010 14:23 |  #2
I've read about several users who have had trigger button problems with different cameras, even if I don't know if any had any problem with a 7D in particular. But in general, this is a recurring issue.
Anders
tsaros
Sep 18, 2010 15:29 |  #3
My 7d has a issue with my 70-200, but only after ~25 shoots or so, then it wont autofocus or meter for a while, then it works for a few shoots and then it doesent and so on.
Same lens works 100% on another 7D and also on my 30D.
And all my other lenses works 100% with my 7D.
It is currently in for service at a local canon repair center since the wireless flash controller decided to stop working, i did mention the issue with the lens and they said that they will have a look at it.
// Andreas.
Eos 30D + grip + rrs, Eos 7D + grip + rrs
Sigma 10-20EX, 24-70EX and 70-200EX Macro,30 1.4 EX, 50 1.4 EX, 580EX,430EX II, Manfrotto MF3, 468MG + rss, Skyports.
FlyingPhotog
Cream of the "Prop"
Sep 18, 2010 15:31 |  #4
Are you certain that you had solid focus when it failed to fire?
Jay
rawkhopper
Sep 21, 2010 19:44 as a reply to  @ FlyingPhotog's post |  #5
No, I didn't have focus because when I tried to push the button part way to achieve focus, nothing happened.
I brought it to the local Canon service centre yesterday. The girl at the main desk cleared my settings and declared the camera fixed. I haven't had a chance to play with it, hopefully tomorrow but I'm not really confident that it was fixed. Honestly, the girl didn't seem to know what she was doing. She couldn't find the centre focus point and asked me to help her out. She told me that I shouldn't use the P mode because then the camera would choose the focus points for me. What???? not true at all, I control the focus points and use the expansion points. Then she told me that should use the Tv mode because you can control the depth of field :confused: Well, you can do that in P mode as well but if D of F is your worry, why would you be in Tv mode? Oy.
I honestly left frazzled, confused and not very confident.
FlyingPhotog
Cream of the "Prop"
Sep 21, 2010 19:47 |  #6
Well, if your camera won't lock focus, it won't fire...
You might consider divorcing AF from your shutter button and using the back button only...
Jay
chomish
Sep 21, 2010 19:48 |  #7
I too feel like my 5D2 button in not 100% at times. I sometimes press it halfway and it beeps more than once. Or not at all.
:) 5D-2 Mark ii :) 16-35 2.8L | 24-70 2.8L | 85 1.2 IIL | 70-200 f4 ISL | 70-200 2.8 IS IIL | 24-70 2.8L |MP-E 65 | 580EX, 430EX, MT24-EX | :p :p :p
rawkhopper
Sep 22, 2010 06:55 as a reply to  @ chomish's post |  #8
Now there's a good idea. Although I'd still like my shutter button to work. I haven't used the back button on my 7D but I used to use it all the time on my 30D :)
ETA: Jay, sometimes the camera did fire and it wasn't locked in. I have had a few totally blurry shots. Hopefully, it will stop raining and I can play this afternoon.
hpulley
Sep 22, 2010 09:57 |  #9
You still need the shutter button to take the picture (unless you use a grip or a remote) so if your shutter button is now troublesome like so many other 50D, 40D, 30D, etc. bodies then it will likely need repair. Still under warranty, isn't it? Send it in...
flickr (external link) 1DIIN 40D 1NRS 650 1.4xII EF12II Pel8 50f1.8I 28-80II 17-40L 24-70L 100-400L 177A 199A OC-E3 RS-80N3
Skrim17
Sep 22, 2010 10:04 |  #10
I am having trouble with my 5D2 not focusing regardless of the button, shutter or back, on occasion. It is more frequent with my 24-70 but has happened with the 70-200 as well.
Crissa
RAGster
Sep 22, 2010 19:58 |  #11
Don't forget that if you are using AI Servo you can set the AF priority to "Focus vs Shoot" which would prevent the shutter release if focus lock has not been obtained (Cfn III-2) and you can set the lens drive to focus search (Cfn III-4). Either of these modes might create the symptoms you describe.
Glenn
lensmen
Joined Oct 2004
Sep 22, 2010 22:46 as a reply to  @ RAGster's post |  #12
The 7D has the ability to be customized. Sometimes these user settings, when misunderstood, can make it felt like the 7D was a complete let down.
I almost threw away a good cable release, thinking that it was faulty. Only to find that it won't fire unless it has focus locked and I was testing it with camera facing the floor.
Jimmy
Just my 2 frame's worth :D:D:D
My Gear List
500px album (external link)
3,836 views & 0 likes for this thread, 9 members have posted to it.
765 guests, 156 members online
