Thread started 19 Sep 2010 (Sunday) 02:46
HELP needed for flash football
ChrisK10
Sep 19, 2010 02:46 |  #1
So after doing a lot of research on this site, I decided to bite the bullet, buy a flash bracket, sync cord and try my hand at using the flash at this weeks game. I mounted the flash about 18" above the camera and started with the flash in ETTL mode 0 flash compensation. I used my 7D, 70-200 2.8, 1.4 converter, and a 580exII flash. My beginning settings were f/4, ISO 800 w/ 1/250. This left the images underexposed and the flash would not reach to the center of the field. I adjusted my flash settings to be +1 2/3 w/ ISO up to 3200. Still found images under or over exposed w/ a lot of motion blur. It also seemed like the colors seemed to change, probably due to my WB. I tried auto and custom WB.
Any help you can give so I can make this flash work would be greatly appreciated.
#1 QB standing in the center of the field. 1/200, f/4.0, ISO Speed 2000, Flash compensation 1
IMAGE: http://farm5.static.flickr.com/4083/5002594651_3d849c9f61_b.jpg
#2 Near sideline. 1/250, f/4.0 , ISO Speed 2000, flash compensation 2/3
IMAGE: http://farm5.static.flickr.com/4090/5003201634_988127c957_b.jpg
#3From the endzone runner is about 20 yrds out. 1/400, f/4.0, ISO Speed 3200, Flash compensation 1 2/3, flash set for high SS.
IMAGE: http://farm5.static.flickr.com/4125/5002597703_3efa3cf0f9_b.jpg
#4 This one came out the best. Was from about 15 yrds out. 1/400, f/4.0, ISO Speed 3200, Flash compensation 1 2/3, flash set for high SS.
IMAGE: http://farm5.static.flickr.com/4107/5003204994_7cb3269612_b.jpg
#5 from about 15 yards, 1/400, f/4.0, ISO 3200, Flash compensation 1 2/3, flash set for high SS.
IMAGE: http://farm5.static.flickr.com/4148/5002599407_b53ba82223_b.jpg
As you can see I got a wide array of exposures, some okay and others not so much. Any help you could give to help me get more consistent would be appreciated.
7D gripped / Rebel XS / 70-200 f/2.8 L IS / 50mm f/1.4 / and some other stuff
Gatorboy
Sep 19, 2010 06:12 |  #2
Can't see the EXIF data, so not sure what mode you were in. You should be in manual, not Av or Tv. Keep your shutter speed at or below your sync speed. You do not want to use HSS. This extends the flash duration and causes your flash to work harder and waste batteries.
You said you mounted it 18 inches above camera. Are you sure it was aligned properly (i.e. illuminating the same area you are focusing on?). What was the ambient exposure, for it looks like you are getting too much ambient lighting mixed in as well, except for the last few that the action was closer.
Dave Hoffmann
Tim ­ S
Sep 19, 2010 12:37 |  #3
Are you using a monopod? If so,you might try mounting the flash on the monopod 12-18" below the lens. Try M, 1/250, f/4, ISO 3200, FEC +1.
Tim
Equipment
ChrisK10
Sep 19, 2010 15:00 |  #4
Gatorboy wrote in post #10935873 (external link)
I was shooting in Manual and I kept the ss at 1/250 or below and 1/500 or below if I was in high sync mode.
As far as alignment goes, I tried my best and played around with the flash because I wasn't sure if I was shooting over the players when I stood, but I had the same issues while kneeling. When I switched to ambient, I was shooting at f/2.8, ISO 6400, 1/500 or 1/640.
I am using a monopod and I will try mounting below. As far as your settings, that is basically what I used w/ it mounted above and the flash wasn't reaching to capture mid field action.
Dan-o
Sep 19, 2010 15:28 |  #5
Chris the short of it is.....it is not that easy. I think most people just assume you throw a flash on, provide your own light, and you get great images.
I have found there is a very small sweet spot in your balance of flash and ambient. I'm constantly chimpping and adjusting things the whole game.
As you have found ETTL is not perfect but I still think it is the most consistent. I very rarely ever go past +1 (usually +1/3-+2/3) and have no problems shooting all the way across the field. What zoom and metering are you shooting at on your flash?
People that just throw out settings aren't there and have no idea what exact conditions are. Two weeks ago I was F4, 800 ISO, 300s, +0 FEC. This week I was F2.8, 1000 ISO, 250s, +2/3 most the game. This weeks field was very dark ( F2.8, 6400, 200s for ambient) I posted some on my FaceBook page, link in my sig.
It takes some time to get it dialed in. Also favor a little low over high when you are angling your flash.
Danny.
DMunsonPhoto (external link)
Cycling Illustrated (external link)
FaceBook Page (external link)
John ­ Godwin
Sep 19, 2010 16:09 as a reply to  @ ChrisK10's post |  #6
Try this. Shoot the camera in Manual mode. Set your ISO and aperture so that your exposure is two stops below ambient. If the camera does not default to the flash sync shutter speed required by the body then set it for that. I believe that is 1/250 for the 7D. Put the flash in ETTL and manually set the zoom for its longest length. In the case of an 580ex II that is 105mm. If you do not think you have the flash centered then put on a wider lens and take test photo. You should be able to determine whether everything is okay.
With those setting I can easily overcome stadium lights to get a good white balance out to at least 40 yards and 50 to 60 is possible with some small adjustments in post processing with the 580exII.
Maxpreps profile (external link)
ChrisK10
Sep 19, 2010 18:14 |  #7
Thank you for the comments.
Dan
Make no mistake I knew this would be a learning venture for me. Your shots looks fantastic so you have definately figured it out. I hope to work my way toward getting shots like yours.
I was in ETTL with auto zoom. But after reading John's suggestion it makes sense that I was wrong to have auto zoom. I will be heading out to the late practice this Tuesday to try again. Hopefully as the season progresses I will be able to dial everything in.
One more question which I'm not sure about because I am not very good with the flash even on still objects. Should I set my WB for flash or do I use a custom WB for the stadium lights as I did in these photos?
Thank you again to everyone for the help.
Dan-o
Sep 19, 2010 18:50 |  #8
I didn't mean you in general Chris. I've tried custom WB and seem to get the same results with just setting it on auto and deal with it in LR.
Yes just set zoom at 105mm and leave it.
A lot can be done in post as well. What are you using?
HTTP response: 404 | Byte size: ZERO
Danny.
ChrisK10
Sep 19, 2010 19:32 |  #9
I use LR3 for PP. I do appreciate your help with how to dial this in. I have been shooting ambient since last year and I always want my shots to get better which is why I'm trying flash. I really like how it makes the colors pop and how it fills in the face masks.
clarence
Sep 19, 2010 20:13 |  #10
Dan-o wrote in post #10937879 (external link)
Danny's flashed football shots are always some of my favorites, so heed his advice.
Looking at your pictures above, my first impression is that your ISO is too high, so the flash isn't able to overpower the ambient.
Another clue is the lack of shadow behind the player, so your flash isn't enough to overpower ambient.
But that's easy to fix if you just drop ISO. Usually 400-800 works fine. 2000 sounds way too high.
I don't have a 7D, but all of my other cameras (1D3, 5D, and T1i) have a light meter in the viewfinder. There's a little tick mark for the flash exposure (it moves a tick when you adjust FEC). And there's another tick mark that indicates the light level when you half-press the shutter button. Just make sure these tick marks are 2 to 3 stops apart from each other. You can adjust ISO or aperture to move the ambient tick.
Another neat tip is that after a shot, the flash tick mark in the viewfinder will disappear until the flash is fully recharged and ready to fire. No more looking to see if the red light is re-lit on the EX.
For Sale: 1D, T1i, 800mm, 600mm
5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/A​C9s
LoCo-Photo.com (external link)
Dan-o
Sep 19, 2010 20:29 |  #11
Those aren't mine Clarence.
Danny.
clarence
Sep 19, 2010 20:56 |  #12
I know. The pics are Chris's (OP).
ChrisK10
Sep 19, 2010 21:02 |  #13
Clarence
Thanks for the suggestions. I looked at my 7D and I don't have a separate tick for the FEC. I only have one for ambient exposure. When my flash is on w/ FEC I only see an icon in the view finder.
I started my ISO at 800 but still had very dark images....Now I think that was because I had the wrong settings on the flash. LIve and learn. That's why I like this site. I have learned a lot about different techniques from people, like yourself, who take very nice shots.
Thanks for the info. I will practice a bit more before this weeks game and take all info here to see what I can come up with.
Dan-o
Sep 19, 2010 21:07 |  #14
Ahh I read it wrong Clarence.
Yes as Clarence said lower your iso. That is the whole reason you are using flash.
Also as Clarence points out different bodies act a little different. I shoot a little different with my MIIn then I do with my MIII.
Danny.
Dan-o
Sep 19, 2010 21:13 |  #15
Chris try to shoot in manual with your flash for a bit. This will at least take out the possible problems with just getting bad metering with your flash.Try 1/4 to 1/2 power.
Chimp, zoom in real close and look for ghosting as well.
Danny.
2,282 views & 0 likes for this thread, 8 members have posted to it.
1139 guests, 178 members online
