n1as wrote in post #10937393
I'm going through the same "hunt". I narrowed my search down to 2:
- Lowepro Rover AW
- Mountainsmith Borealis AT
The Rover will apparently hold a 32 oz water bottle while the Borealis won't. I ended up ordering an Osprey Kestrel 32 backpack plus the Mountainsmith Kit Cube insert. About the same price as the Lowepro Rover AW which was my next choice. I believe the Osprey will be much more comfortable to carry and will be more versatile.
I'll know later this week when my stuff arrives.
Actually, it'll carry two 1-liter nalgene bottles in the elasticized side pockets. Then there's the well-thought out tripod carrier of the Rover. The Rover also has the two separate compartments, which makes getting to other essentials much easier. Single compartment packs require you to rummage through to find things. TBH, I've been shooting for many years, and the Lowepro Rover (as well as the Dryzone Rover that I have) are probably two of the better thought-out "camera specific" backpacks that I have ever used,and I've used a bunch.
The problem with most "real" backpacks, at least to me, is that the vast majority are top-loading only. Sliding a camera bag insert puts your gear at the bottom, and you'd need to rummage through whatever you may put above it to get to the gear. Vice versa if you put the insert at the top.
That being said, I came across a Deuter 32L trail pack that sort of solves that problem. Top loading, but it also has a large front zipper down below that will also open the pack from the bottom front. I'm waiting on an F-stop gear ICU to put in the pack...the bottom zipper will allow me access to the camera gear, while the top zipper will let me store essentials above the ICU. Not as convenient as having two xseparate compartments, but it'll do. If this works out, I plan on having a local seamstress sew a Canon L lens pouch on the inside seam of the bottom zipper...this I can flip out to to secure the tripod feet while using the pack's bungees to secure the top of the tripod. When I don't need the tripod, the pouch can simply fold into the pack before zipping shut. Hopefully, the ICU will get here soon so I can continue the experiment.
