POTN forums are closing 31.12.2023. Please see https://photography-on-the.net/forum/showthread.php?t=1530921 and other posts in that thread for details.
Thread started 19 Sep 2010 (Sunday) 12:42
Old Film flash making my batteries burst
Deep ­ Pocket
Sep 19, 2010 12:42 |  #1
So I have two 540EZ old Film flashes. They work great and all especially for their price, just I can only use Manual mode.
Now, lately for some reason whatever batteries I put in one of them, a couple days later I'll find that the batteries have bursted (weird white and brown liquid flowing out of the top). This isn't the first time it happened either- after swapping them, the next time I find out my flash doesn't turn on I find that the batteries have bursted again.
After they've bursted of course I'll have thrown them out (well, recycle), cleaned the area touched by the battery guts with a little cleasing alcohol, and put new ones in.
I use Duracell batteries.
Anyone have an idea what could be causing this?
EDIT: Now my flash doesn't work regardless of which batteries I use.
17 and learning..
Canon Rebel XSI/450D:
Sigma 30 f/1.4, EF-S 55-250mm f/4-5.6 IS, 18-55 Kit Lens
Deviantart (external link)
nes_matt
Sep 19, 2010 17:13 |  #2
1) were they all from the same batch?
2) are you absolutely certain you put them in the right way? Being installed backward might have caused this.
Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
Flickr photo stream (external link)
Portfolio (external link)
Facebook Page (external link)
Deep ­ Pocket
Sep 19, 2010 17:35 |  #3
Can't quite remember whether they were from the same batch or not, but I was 100% sure I put them on the right way- flash works no problem right after
17 and learning..
isoMorphic
Sep 19, 2010 17:36 |  #4
Sounds like a short from the first time you had a leak due to leaving old batteries in the device which is completely draining the new batteries. My advice would be to stick a piece of plastic, tape or non conductive material across one side of the contacts or remove the batteries entirely when not in use.
Deep ­ Pocket
Sep 19, 2010 19:16 |  #5
OK, now my flash is dead.. no batteries work :(
17 and learning..
GeneMan88
Joined Jan 2005
Sep 19, 2010 19:21 |  #6
Sounds like there is a short within the flash units themselves.
1D MKI + 1Ds MKI + 5D MKI Kit - EF17-35 f2.8L | EF24-70 f2.8 L | EF 100-400L IS | EF15 f2.8 | EF35L | EF50 f1.4 | EF85 f1.8 | EF135L | 580EX II | 580EX I | 270EX II | G12
PDX/Vancouver Photography Meetup Group (external link)
isoMorphic
Sep 19, 2010 20:12 |  #7
Time to open it up and clean the corrosion off circuitry with a swab of soda water or alcohol followed by some clean water. If it does not smell burnt chances are it's not totally dead and can be revived. Usually if the corrosion gets real bad it can destroy resistors on the board but it might be the contacts which are shorted.
Since its dead at this point anyway it's worth taking apart but be forewarned flash capacitors hurt like hell if you get zapped. So once you open the device be sure to short the contacts of any capacitors inside with a screwdriver to safely discharge before handling.
1,418 views & 0 likes for this thread, 4 members have posted to it.
2217 guests, 101 members online
