FORUMS Photo Sharing & Visual Enjoyment Still Life, B/W & Experimental
Thread started 20 Sep 2010 (Monday) 10:38
Miniature Lego Car
tkerr
Sep 20, 2010 10:38 |  #1
These were taken using a makeshift light box and a couple cheap utility lights.
The box is a translucent white plastic storage container that you can by at any department store. dimensions are 16"x22" x 12"deep.
I set up one light at the side with a piece of Aluminum foil on the opposite side as a reflector, and then another light on top shining downward. The flash is the 580EX II with a home made Diffuser.
All are shot at ISO 400 and lens at 135mm. Distance from lens to subject was approximately 1 foot.
Usually for something like this I will set and use CWB, but this time I just used the AWB
First was shot at f/9 using spot metering mode. Second was shot at f/16 using evaluative metering, and the third was shot at f/22 using evaluative metering.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i68.photobucket​.com …20Images/Legoca​r-f9SM.jpg (external link)
http://i68.photobucket​.com …mages/Legocar-f16Eval.jpg (external link)
http://i68.photobucket​.com …mages/Legocar-f22Eval.jpg (external link)
Tim Kerr
F1, try it you'll like it.
631 views & 0 likes for this thread
Miniature Lego Car
Latest registered member is mobbed2001
892 guests, 429 members online
