Which would you prefer?
I can have both with almost the same price...I have also canon 100mm macro L and sigma 50mm 1.4...
I shoot mainly portraits, landscape and C...
Enrico81 Member 161 posts Likes: 1 Joined Feb 2008 Location: Italy More info | Sep 20, 2010 11:04 | #1 Which would you prefer?
Sep 20, 2010 11:05 | #2 Obviuosly canon 7d + canon 24-70mm L Vs 5d MK II + Tamron 28-75mm...
Sep 20, 2010 11:11 | #3 If your sig is correct and you already have a 5Dc I would just get a 24-70. Website
jacobsen1 Cream of the Crop ![]() 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Sep 20, 2010 11:14 | #4 what comes after the C..... My Gear List
Sep 20, 2010 11:16 | #5 I'd like 5d mkII because I like modern features and filming....I know cameras are made to make pictures...but I like it...
Sep 20, 2010 11:17 | #6 jacobsen1 wrote in post #10942873 ![]() what comes after the C..... the 7D has bells and whistles galore and everything BUT the sensor is PERFECT. The 5Dii has that perfect sensor (for most people/things) but it's AF isn't that great and it's layout isn't quite as nice. Do you need FPS? AF? better liveview? Probably would be perfect the 5d mk II, but it's more expensive...so I'm evaluating what's better to me...
cobra671 Senior Member ![]() 340 posts Joined Nov 2009 Location: South Florida More info | Sep 20, 2010 11:22 | #7 Clearly, the 7D is what you should get then.
Sep 20, 2010 11:25 | #8 I think 7d could be the right solution, but the iso quality of 5d mk II is amazing...
ThePupD Senior Member ![]() 360 posts Joined Aug 2010 Location: The Netherlands More info | Sep 20, 2010 14:26 | #9 5d2 with 24-70 graphic designer & part time photographer
Sep 20, 2010 16:14 | #11 Obviously 5d mkII + 24-70mm, but it's too expensive!
ThePupD Senior Member ![]() 360 posts Joined Aug 2010 Location: The Netherlands More info | Sep 20, 2010 16:21 | #12 Enrico81 wrote in post #10944587 ![]() Obviously 5d mkII + 24-70mm, but it's too expensive! I don't know if I would have better feeling with 5d and tamron or 7d and canon 24-70mm... I could take 7d and 24-70mm, and when there will be 5d mk III I could change with 5d mkII... hmmm don't know. in my opinion.. the 5D is so much nicer! graphic designer & part time photographer
Sep 20, 2010 16:31 | #14 probably I'll go for 7d, but now my doubt is if the extra money is worth for a canon 24-70mm or is enough a tamron 28-75mm...
ThePupD Senior Member ![]() 360 posts Joined Aug 2010 Location: The Netherlands More info | Sep 20, 2010 16:37 | #15 Why a 7d..... 5d is the way to gooooooooo graphic designer & part time photographer
y 1600 |
Log in Not a member yet?
Latest registered member is Neverlost99 1138 guests, 211 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 |
