jacobsen1 Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Sep 20, 2010 12:56 | #1 yep. Kenko 1.4 TC used (not reported in EXIF). Filters works. Elements touch at ~12mm is so I stuck to around 13mm (17mm ish). My Gear List
ni$mo350 Cream of the Crop 6,011 posts Likes: 14 Joined Apr 2009 Location: Portland, OR More info | Sep 20, 2010 13:06 | #2 |
jacobsen1 THREAD STARTER Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Sep 20, 2010 14:32 | #3 ni$mo350 wrote in post #10943494 Those came out pretty cool. Why not just sell it and put it towards a 17-40L I'm on the fence between keeping a 5D with my 7D or going JUST crop... Also, had this really worked down to 10mm it'd be 14mm on FF WITH filters which would be amazing. But as it is, if I keep the 5D I'll swap the 10-22 for a 17-40. The other option is selling the 5D for a 24-105 and 50 1.4... My Gear List
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Cool shots, Ben... but who is Mike Kwasnicki? connecticut wedding photographer
redfire2002 Member 189 posts Joined Feb 2009 More info | Sep 20, 2010 14:51 | #5 i like your exif viewer, mind sharing what you use? Canon Gripped 5D II & 1D III ::: Canon EF 24-70L f/2.8 ::: Canon EF 70-200L f/2.8 ::: 580EX II & 580EX
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Sep 20, 2010 14:53 | #6 redfire2002 wrote in post #10944116 i like your exif viewer, mind sharing what you use? It's a Safari 5 extension called ExifExt - you can get it here: connecticut wedding photographer
jacobsen1 THREAD STARTER Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Sep 20, 2010 15:01 | #7 buhahahahah! My Gear List
rusty.jg Senior Member 855 posts Joined Mar 2009 Location: Cornwall, UK More info | Hi Jacobsen - fantastic photos by the way. to be OR NOT to be = 1 (which is "to be" so that one's cleared up at last
chomish Goldmember 1,917 posts Joined Jun 2007 More info | Sep 20, 2010 15:07 | #9 Beautiful shots Mike Kwasnicki. You really caught a beautiful seen Mr. Kwasnicki...
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Sep 20, 2010 15:10 | #10 Great shots! [Gear List | Flickr
jacobsen1 THREAD STARTER Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Sep 20, 2010 15:16 | #11 rusty.jg wrote in post #10944190 Apologies if I sound a bit daft - I dont understand the whole "with filters" bit and how they could be a problem? I thought filters fitted on the end and thats it? no worries, I'm pretty sure I'm the ONLY person who's ever done this, at least on PotN and flickr (someone did it with a sigma 10-20 which gave me the idea). Also did you put the TC on and then the 10-22 but as you wind back the lens to 10mm, the rear element touches the glas on the TC? exactly. Keep the marker from touching the right side of the 12mm mark and you're safe. It's roughly 17mm and up, so if you want to keep this lens it works, but a 17-40 is probably smarter? My Gear List
rusty.jg Senior Member 855 posts Joined Mar 2009 Location: Cornwall, UK More info | Ah, ok - thanks for that, it makes a bit more sense now. So basically you're trying to avoid the pitch-black vignetting from hell because its so wide and also the sound of glass crunching glass. to be OR NOT to be = 1 (which is "to be" so that one's cleared up at last
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Sep 20, 2010 15:30 | #13 jacobsen1 wrote in post #10944168 how do you even change that on a 5D? It's been a while, but I think you have to hook it up to your computer and change it in DPP. connecticut wedding photographer
jacobsen1 THREAD STARTER Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | Sep 20, 2010 15:36 | #14 rusty.jg wrote in post #10944337 Ah, ok - thanks for that, it makes a bit more sense now. So basically you're trying to avoid the pitch-black vignetting from hell because its so wide and also the sound of glass crunching glass. Which model of Kenko 1.4 TC did you use? yes and the 300 pro DG version. Look at the shots of them on B&H and make sure the element on the lens side is recessed. timnosenzo wrote in post #10944346 It's been a while, but I think you have to hook it up to your computer and change it in DPP. the 5D thread guys saved me, it'd eos utility, thanks! My Gear List
wimg Cream of the Crop 6,982 posts Likes: 209 Joined Jan 2007 Location: Netherlands, EU More info | Sep 20, 2010 16:03 | #15 jacobsen1 wrote in post #10944168 buhahahahah! I'd bet it's either the previous owner or the guy before him? how do you even change that on a 5D? Via th eEOS utility EOS R & EOS 5 (analog) with a gaggle of primes & 3 zooms, OM-D E-M1 Mk II & Pen-F with 10 primes, 6 zooms, 3 Metabones adapters/speedboosters, and an accessory plague
| Latest registered member is semonsters 973 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
