Thread started 21 Sep 2010 (Tuesday) 01:12
your thoughts on the optech super classic
tudragan
Sep 21, 2010 01:12 |  #1
So i have been looking for a camera strap. After some research on POTn, I have come to the conclusion that I will be buying the optech super classic or lowepro voyager.
It doesnt seem like too many people use the lowepro so i am leaning towards optech since the potn like it more. I also noticed that there are two kinds of the super classic. the regular super classic with a pro loop and then there is the super classic with a uni loop. what are the differences between the two?
_Jonathan
Jonathandinh.wordpress​.com <- check out my new blog
Wilt
Sep 21, 2010 12:58 |  #2
If you visit the OpTech web site, you will see closeups of the ends available...they actually have many attachment styles supported. Unfortunately I don't know the uni loop. Unfortunately the web information does not make it obvious what the differences are.
From the web, " The Utility Loop is ideal for adapting the UTILITY STRAP or other strap with snap hooks for use with a camera. Available in sets of two. The new Uni-Loop Connectors allow users to have a universal system with many other OP/TECH USA products"
From OpTech site
"UNI-LOOP
Availability: In stock
MSRP $7.95
•Enables cameras or binoculars to be used interchangeably with OP/TECH USA neck straps, wrist straps or harness systems
•Minimizes the amount of strap left on the camera when the main pad is removed (3.5" in length)
•Fits tight connection areas using a loop of 1/4" tubular nylon webbing
•Sold in sets of two
•Made in the USA
With the OP/TECH USA SYSTEM CONNECTORS, the camera/binocular owner has several connection options. You can buy an extra set of connectors to customize the strap to best suit your needs. Straps can be lengthened to be worn across the chest or shortened to be worn at chest level. Another feature of the SYSTEM CONNECTORS is the small carrying handle created when the quick disconnects are latched together. Download the Info Sheet on the 14 different System Connectors.
The UNI-LOOP System Connectors allow a camera or binoculars to be used with several neck straps, wrist straps or harness systems. The UNI-LOOP System Connector is available in sets of two, with one male and one female connection.
The System Connectors collection includes:
1. Swivel Hooks
2. Adjustable Connectors
3. 3/8" Webbing
4. Pro Loop Connector
5. Super Pro, A
6. Super Pro, B
7. Utility Loop
8. Uni-Loop
9. Uni Adaptor Loop
10. Reporter/ Backpack
11. Adapts-Its
12. Mini QD Converter
13. Lens Support
14. Sling Strap Adaptor
PRO LOOP CONNECTOR
MSRP $8.75
•Available in two fully adjustable sizes: 10" to 13" (Regular) and 13" to 19" (X-Large)
•Uses 1/4" tubular nylon webbing to fit tight connection points
•The quick disconnects can be clipped together to create a small carrying handle
•Made in the USA
The PRO LOOP CONNECTOR uses 1/4" tubular nylon webbing to fit easily in tight connection areas. The PRO LOOP CONNECTOR is available in sets of two, with one female and one male connection.
Available Sizes
Regular: 10" - 13" adjustable each side (25.4cm - 33cm)
X-Large: 13" - 19" adjustable each side (33cm - 48.3cm)
1. Swivel Hooks
3. 3/8" Webbing
5. Super Pro, A
6. Super Pro, B
7. Utility Loop
8. Uni-Loop
9. Uni Adaptor Loop
10. Reporter/Backpack
11. Adapts-Its
13. Lens Support
I have the OpTech Super Classic myself, and an very satisfied by it. Having tried a number of other straps in the past, it is my current strap of choice.
2,342 views & 0 likes for this thread
Latest registered member is Telescopus
1199 guests, 286 members online
