Thread started 21 Sep 2010 (Tuesday) 09:22
Macro: Canon 100 L IS vs. 60 EFS.
Nick5
Sep 21, 2010 09:22 |  #1
Looking into a macro lens.
While the new 100 L has the all important IS, the Canon Ring Flash does not fit.
For the Macro Junkies, how much do you use a is ring flash as this may steer me in the direction of one of the two macro lenses.
Thanks.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
xarqi
Sep 21, 2010 09:37 |  #2
I use one, but only because I have one. I think on the whole the twin macro flash is a better set up, or just a diffused normal flash or two,
JelleVerherstraeten
Sep 21, 2010 10:25 |  #3
I think there're other possibilities that let you use a 100L.
You have 580EXII, so you could buy THIS (external link)
-Jelle l Gear l Website (external link) l
actprivate
Sep 21, 2010 16:49 |  #4
I don't have the macro ring flash and I prefer using available light usually. I use multi-deflected flash set up from time to time for table-top shots but that's a minority.
This image was taken with 7D + 100L at 1/25 s handheld. I don't believe I could do this without IS.
Canon Electro-Optical System
themadman
Sep 21, 2010 17:03 |  #5
Ring flash isn't necessary. I just use regular flash with some kind of diffuser.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Madweasel
Sep 21, 2010 17:39 |  #6
I thought there was an adapter that lets you use the Canon ringflash (or the twin flash) on the 100L, the same as for the 180L.
Mark.
katodog
Sep 21, 2010 18:05 |  #7
I have the 100mm IS L and I use a 550EX on-camera with a Sto-Fen diffuser, works perfectly, no need for extra doo-dads or special flash units. Although the twin-head flash is on my list, it's not a necessity.
1/200, f/8, ISO800, 550EX on-camera with Sto-Fen...
1/200, f/11, ISO800, 550EX on-camera with Sto-Fen...
1/250, f/11, ISO400, 550EX on-camera with Sto-Fen...
The one thing to remember is that you can use either for portraits, but the 100mm L will give you the added benefit of stabilization, which is a good thing. Even at f/2.8, low-light situations will give you a hassle sometimes, and the added benefit of stabilization will allow you to shoot under less-than-ideal conditions.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear- Flickr (external link) - Facebook (external link) - Smoke Photography - - Sound-Activated Paint
MP4/8
Sep 21, 2010 20:43 as a reply to  @ katodog's post |  #8
This is pretty much at MFD with the 60 f/2.8 Macro. You are almost touching them with the front element at this point.
This is wide open at ISO 100, at 1/320. Handheld. No cropping. No flash. It's still feels like there's a tiny bit of motion blur, or missed focus due to movement.
If insects are your thing, I think the 100mm is the much better option over the 60.
IMAGE: http://farm5.static.flickr.com/4122/4924769443_6060948098_b.jpg
Canon T2i ** EF-S 17-55 f/2.8 ** EF 70-300 f/4-5.6 IS ** EF 50mm f/1.8 II ** EF-S 60mm f/2.8 Macro ** Lensbaby ** Canon S5 IS P/S camera
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." : Albert Einstein
katodog
Sep 21, 2010 21:01 |  #9
Another thing to consider is the fact that the 100mm L focuses faster than most macro lenses. I had the Sig 180mm f/3.5 and it was a slug compared to the L.
MP4/8
Sep 22, 2010 00:28 as a reply to  @ katodog's post |  #10
Oh, the other thing, the 60mm does not have IS, although it does have USM. The AF is decent on the 60mm.
KenjiS
"Holy crap its long!"
Gallery: 622 photos
Sep 22, 2010 00:34 |  #11
I love my 100mm f/2.8L IS...
I need to get a diffuser or something, right now i just bounce my 580eXII off the ceiling...its not really the best solution..
Having owned both, the 100L is the way to go, if you have the money you'll kick yourself if you dont get it
Deviantart (external link)
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Sep 22, 2010 00:41 |  #12
Yes, there is a stepdown/adapter ring from 67-58mm. I have one so I can continue to use my MR-14 for my purposes. I think for insect macro, if you want better lighting, go with the MR-24. Having the ability to provide more directional lighting can improve the look of the image. With the ring flash, you're stuck with uniform illumination (which works fine for my line of work). :lol:
Julian
WesternGuy
Sep 22, 2010 02:21 |  #13
Nick5 wrote in post #10948820 (external link)
Thanks.
Actually it will fit, the MT-24EX that is (don't have the MR14EX - so can't comment), but you have to buy an adapter for the 100 L IS macro. I believe it is the Microlite Adapter 67. I don't use the ring light a lot, but it does work with the adapter and works well, once you learn its in and outs. HTH.
WesternGuy
Trovador
Sep 24, 2010 09:42 |  #14
I have the Canon 100mm 2.8L IS and it is an incredible lens. These pics are taken with this lens, a 7D and the pop up flash without a diffuser: (I have two 430exII and a macro ring led light but I'm not using them as so far the pop up flash is working well for me)
IMAGE: http://farm5.static.flickr.com/4087/4977349435_eacba6d97f.jpg
IMAGE: http://farm5.static.flickr.com/4085/4977349701_f47f8b753b.jpg
IMAGE: http://farm5.static.flickr.com/4130/4980978284_551a5ca5aa.jpg
AngryCorgi
-Bouncing Boy- a POTN peion
Location: Surrounded by bunnies, squirrels and a couple of crazy corgis in NoVA...
Sep 24, 2010 09:45 |  #15
actprivate wrote in post #10951575 (external link)
Dude, I don't think I could do that WITH IS...arachnaphobia-city!
AngryCorgi (external link) (aka Tom) ...Tools...
...Knowledge is knowing that a tomato is a fruit, Wisdom is knowing not to include it in a fruit salad...
6,590 views & 0 likes for this thread, 14 members have posted to it.
1474 guests, 131 members online
