Hi all,
I have a quick question:
I was wondering how you get that "star" effect when you have a strobe pointing toward the camera and firing from behind a subject? Same idea as how the sun can look when you're outside and shoot in the range of f16 etc...I was just trying a 'rock star' look with one of my boxers. Here was the setup:
Black background
One strobe to camera left, pointing toward camera. This was an elinchrom 300RX, with just the reflector
The boxer was about a foot in front and to the right of strobe
One 300RX strobe with softbox (100cm x 100cm) to camera right feathering as a main light .
The end result was that the back light was just shy of blowing out - was an OK look but not close to what I wanted.
Should that light in the back be stopped WAY down? Is this an effect that only works when I'm not too close to that light in the back? I thought by bringing the aperture down, that would work but it didn't
I only had 10-15 minutes to mess with this, but he had his fill
I was hoping for a suggestion or two so when I try again on Saturday, I have a starting point.
Thanks!
