Is there really any difference in the same model of lens made 12 or 15 years ago versus one that was made more recently?
Hypothetical example: A person wants to buy a 300mm EF IS f/4 and sees an add for a pristine copy with a date code of UM, which is 1998, and then sees another add for a pristine copy with a date code of UU, which is 2006. The conditions of the lenses are visually equal, so there's no reason to believe the older lens has seen more or rougher use. Let's say, for argument's sake, the older lens is $50 less than the newer lens, a nominal amount. Is there any reason why the newer lens should be preferred to the older lens, all else being equal? Are there any differences in QC or updates to electronics between old and new in any of these lenses (not counting those lenses with major updates, such as the latest 70-200 f/2.8 IS)?
