Thread started 24 Sep 2010 (Friday) 15:03
DIY: Has anyone replicated the LastoLite Triflector from foamcore?
ProjectNineFive
Joined Jun 2010
Sep 24, 2010 15:03 |  #1
I thought about making a home made Lastolite Triflector out of foamcore. Has anyone made one and used it in a studio?
Project Nine Five Photography (external link)
My Facebook Fanpage<----ADD ME (external link)
TMR ­ Design
Joined Feb 2006
Sep 24, 2010 15:19 |  #2
ProjectNineFive wrote in post #10971681 (external link)
Hi there,
Prior to buying the Lastolite Tri-Lite (I believe it's Westcott that uses the name Triflector) I made a DIY version with white foam core to see the effect and to see if I liked it. I fell in love with it but I just didn't feel like making the arms or rigging up a DIY to accomplish what Lasotlite is doing well.... expensive for what it does but hard to find a similar device for less.
I also wanted the Lastolilte panels so it could travel and be used on location. A lot of people forget that they can use it with ambient light and until you've tried it, blending white with silver panels, you haven't really seen how cool it can be.
No, I don't work for Lastolite.. LOLOL
I just happen to really like the Tri-Lite and although I do feel it's overpriced, the same could be said about the majority of the modifiers I use. I wanted that tool in my toolbox and justified it. Some can't.
Having said all that, if you can make something that works for you and gives you the full range of adjustment then please share it so others can see. With foamcore you can have white, silver (painted or covered), black for negative fill... and any combination of those.
Robert
Karl ­ Johnston
Sep 24, 2010 20:30 |  #3
I use foamcore all the time
Foamcore wrapped in silver or gold paper for contrasty/warmer contrasty light
I just ghetto rig it to a light stand with a piece of tape and away we go.
I kinda used it with 4 panels in this shot, though it's not very well executed. Used a PLM to blow out the seamless from behind the model.
oops...correction...I used a 580 ex above and pointed down to light the foamcore. *not natural light in these two. Was wondering about the hot side on her cheek.
I like how it creates multiple catchlights for literally $1.50
You can't see it terribly well in this shot, plus I screwed up and shotin Adobe colorbalance instead of rgb so the colors are a bit tinted, though you get the idea with the lighting.
Adventurous Photographer, Writer (external link) & Wedding Photographer (external link)
TMR ­ Design
Joined Feb 2006
Sep 24, 2010 20:47 as a reply to  @ Karl Johnston's post |  #4
Nice shots Karl.
If I didn't need or want something that packs, stores and travels well, I'd be using foam core a lot more. I find white foam core to be some of the softest light to return from a reflector.
I just didn't find it practical in the Tri-Lite application. Like I said, it's all about the ability to adjust in any and all directions easily and quickly.
Robert
blurry_image
Sep 25, 2010 00:20 |  #5
TMR Design wrote in post #10971765 (external link)
Hi there,
can you give an example shot where you did that and explain to me (a newb) why you would do that? thanks a bunch!!
also, 200 bucks isn't that bad considering it should last "forever"
Chris
TMR ­ Design
Joined Feb 2006
Sep 25, 2010 08:07 |  #6
blurry_image wrote in post #10974292 (external link)
Hi Chris,
I wish I did have a sample to post. Unfortunately when I had the opportunity to use the Tri-Lite this way it wasn't on my own shoot and I don't have the images.
The reason we mixed white and silver was to balance soft light with a more specular light. We used the silver panel on the center and directed as much light as we could get under the chin and on the neck. We couldn't bring it up real close due to the way we wanted to frame the shot. The 2 white panels were used on the left and right sides with one side further away from the face than the other to keep some contrast between highlight and shadow.
Robert
Karl ­ Johnston
Sep 25, 2010 17:08 |  #7
TMR Design wrote in post #10975257 (external link)
Hi Chris,
Was there a reasonable difference when you did this compared to if you were to do it with 3 white panels? That sounds pretty cool
blurry_image
Sep 26, 2010 05:54 |  #8
Hi Chris,
Makes sense - thanks Rob!
Chris
MrScott
Sep 26, 2010 23:52 |  #9
So much more than just a DIY reflector video...
http://vimeo.com/13803​951 (external link)
charlieharper
Sep 27, 2010 05:46 |  #10
Can I link to another Forum here ?
What if it means I am plagiarising myself :p ??
I really haven't got much of an idea what I'm doing as far as photography goes, this was done when I had even less of a clue :D :D !!!
On PhotoCamel (external link).
The results on PhotoCamel...........
Clicky Linky Thingy (external link).
Notice the unusual catch-lights in the bottom of her eyes !!
YMMV !!
I just want to take nice photographs of people.
My SmugMug pages. (external link)
skrezyna
Nov 15, 2010 13:08 |  #11
Robert,
Which set would you suggest buying first? White/gold or white/silver?
Hi there,
http://www.danskrezyna​.com (external link)
5D w/BG-E4,
[35L f/1.4] [50 f/1.4] [85 f/1.8] [135L f/2] [70-200L f/2.8 IS]
580EX-I
Seanzky
Nov 15, 2010 13:40 |  #12
MrScott wrote in post #10984469 (external link)
Awesome video!
TMR ­ Design
Joined Feb 2006
Nov 15, 2010 15:18 |  #13
skrezyna wrote in post #11288509 (external link)
Robert,
Hi skrezyna,
I'm not a big fan of Gold reflectors and use them very infrequently. I own and really like the white/silver panels. Unless you know you like the effect of the gold reflector I wouldn't get it.
Robert
6,585 views & 0 likes for this thread, 8 members have posted to it.
963 guests, 184 members online
