Thread started 22 Aug 2005 (Monday) 13:14
New problem with G6 and 420ex
jon1996
Aug 22, 2005 13:14 |  #1
While taking pictures outside with my G6 and 420ex, In p mode and av both it will not focus and camera shake is on whter I am handheld or on a rest, also the pics are very dark when they should be right due to having plenty of light, Why is this?
thanks,
jon
Canon 20D
18-55 IS, 55-250 IS, 50 1.8,
Panasonic FZ50
Canon G6 with about 40,000 Pics
www.jonsphoto.smugmug.​com (external link)
twalker294
Joined Jan 2002
Aug 22, 2005 23:06 |  #2
Can you post a sample with EXIF?
Todd Walker
http://twalker294.post​erous.com/ (external link)http://www.twphotograp​hy.net (external link)
Canon 40D, 10D, G9, SX20IS, and SD500
kring
Aug 25, 2005 11:18 as a reply to  @ twalker294's post |  #3
I had a post on this a month back, same issue. I consider it a flaw in the camera but other's don't. I've found that your flash batteries are most likely dead, the flash will still go off, but something about not having fully charged batteries causes the flash to tell the camera when it's focusing and locking "do not use the flash" I've had my camera go all the way to 2" exposure with the flash on. I call this a defect that the camara will go so far under acceptable shutter speed to compensate for ambiant light, even if there is a flash attached. There should be some way to lock or set a preference. for some reason Canon has coded the firmware to do it's best to go for 1/60 shutter speed, even in there's enought light to go 1/250 wiht perfect exposure, the camera will always go for the slowest shutter speed it can. This causes your shaky hands icon and blurry pictures. I would code a camera to always use the highest shutter speed possible to avoid blur, but I'm no expert, just going off common sense.
IMO Somewhere between the G6 and 420EX there's a bug.
From my experience your issue is the flash batteries. then if that still doesn't work, your in the same boat as me with a bad camera firmware. No fix at this time.
Canon 30D
Canon Rebel XT Silver
Canon EF 50mm f/1.4 USM
Canon EF-S 17-85mm IS USM (Hoya Pro1 UV & Lens Hood)
Canon 430EX Flash (Sto Fen Omni-Bounce)
HungryWriter
Gallery: 10 photos
Joined Jun 2005
Aug 25, 2005 12:10 |  #4
Are you sure your flash adjustment settings aren't off? Flash output can go between -2 stops to 2 stops. Make sure its at 0.
Also you can set to 1st curtain (a flash right after your shutter opens) or 2nd curtain (a flasht right bfore your shutter closes).
Set to 1st curtain for 'normal' flash settings.
Post EXIF with a pic so we can see what's going on.
[Canon g7x mark III] & [Canon G7x mark II] [Canon SX200IS] [Canon SX170IS] * [Canon Rebel EOS T1i] [EF 35mm f/2.0] [EF 50mm f/1.4 USM] [EF 85mm f/1.8 USM] [EF-S 18-55mm f/3.5-5.6 IS Lens] [EF-S 55-250mm f/4-5.6 IS Lens] [Giottos MTL Tripod]
*Follow me on Twitter (external link)*
stjuste
Joined Nov 2005
Nov 12, 2005 17:31 as a reply to  @ HungryWriter's post |  #5
I've also experienced this problem. When I first used the 420EX with the G6, I thought it was great and I often got great pictures. Now that I've been using it for awhile, I am noticing the same underexposed picture results. I haven't seen the 2" shutter speed but I am seeing a constant 1" shutter speed even though my flash is connected. I will post a picture with EXIF data soon.:(
5D | 30D | 20D
16-35 f2.8L | 24-70 f2.8L | 35 f1.4L | 50 f1.4 | 85 f1.8 | 100 f2.0 | 200 f2.8L
AndreyD
Joined Jan 2003
Nov 13, 2005 02:22 |  #6
Have to check in G6 menue - that flash setting set to automatic, not manual
Andrey
Moscow, Russia
flickr (external link)|blogger (external link)|facebook (external link)|livejournal (external link)|project365 (external link)
woffles
Nov 13, 2005 09:54 |  #7
Make sure your flash isn't set to slow sync.
Film is what you get when you don't brush your teeth.
stjuste
Joined Nov 2005
Nov 13, 2005 11:54 |  #8
Strange thing is that when I set it to slow sync, the pictures in P mode come out exposed correctly. It is almost like by using this setting, the camera is able to wait a little longer to capture image with flash. I wonder if it is the flash that is not being powered correctly or strongly enough. I am using regular duracell batteries that I recently bought. Could it be that the batteries that came with the flash are of a special type and that I need to get those types instead of regular duracells?
On another note, when I go to manual mode and set setting myself, the pictures come out much better. I'm still a little upset that the pictures in P and auto modes don't expose correctly with the external flash. Any ideas are welcome.
Where is the flash setting in the G6 menu? I reset the camera to default settings and am still getting the same results.
5D | 30D | 20D
2,041 views & 0 likes for this thread, 7 members have posted to it.
1798 guests, 115 members online
