POTN forums are closing 31.12.2023. Please see https://photography-on-the.net/forum/showthread.php?t=1530921 and other posts in that thread for details.
Thread started 25 Sep 2010 (Saturday) 00:55
Is full-frame really that dramaticly better?
Deep ­ Pocket
Sep 25, 2010 00:55 |  #1
OK, I'm sure there have been plenty of 5D vs 7D debates.
Now, I figured that the crop factor of the 7D would be ideal for many situations, and would help me get that extra reach, while only the 5D it would be easier to go wide.. but, I could always get some wide lenses like the Sigma 8-16 that would be perfectly fine on the 7D.
Portraits and landscapes look more dramatic on the full-frame sensor, and I get better ISO.. sure, but is it really that much better? I'm a student so I can't afford both, and the other issue is I don't want to buy used items (since I can't recall seeing a 5D used somewhere, and I can't afford the 5DII) due to bad luck with the last flash I bought used. Also, going full-frame would mean I would have to replace ALL my lenses..
The main thing that wants me to upgrade my XSI is I long for a better AF, and I heard the 7D has better AF. I'm currently fine with my lenses, the only one I'm really eyeing is the MPE 65.
17 and learning..
Canon Rebel XSI/450D:
Sigma 30 f/1.4, EF-S 55-250mm f/4-5.6 IS, 18-55 Kit Lens
Deviantart (external link)
bindabinjo
Sep 25, 2010 01:13 |  #2
i was actually gonna start a thread just like this one a second ago. it's good thing i checked the active threads beforehand.
anyway, I own a T2i right now, and I've been reading as many comparison threads as possible on the differences between the T2i and the 5Dc. Most, if not all, threads suggest that the full-frame sensor on the 5Dc would "blow away" the t2i's crop sensor in terms of image quality, especially in dealing with portraits.
So, does anyone have some sample image comparisons between the t2i and 5Dc (preferably of the same subject under similar lighting)? I haven't come across any image comparisons in other threads, so I'm not sure if trading in my t2i would be worth it.
Also, I haven't used the video mode as often as I thought I would on the T2i, so I doubt I'll miss it. And the built in flash isn't much of an advantage, since I plan to buy an external flash.
**Didn't mean to hijack the thread, but I figured it goes along with the OP's concerns.
Kevin
Staszek
Sep 25, 2010 01:19 |  #3
The argument against FF vs crop is not going wider or longer, its about DOF. The FF sensor is capable with significantly shallower DOF than a crop sensor on any lens. As you mentioned, you can easily grab a wider lens and be "just as wide," but you'll never match the shallowness of the shot. The dramatic effect comes from the shallow depth of field.
5Dc's are common in the FS section.
SOSKIphoto (external link) | Blog (external link) | Facebook (external link)| Instagram (external link)
Shooting with big noisy cameras and a bag of primes.
tonylong
...winded
Gallery: 60 photos
Sep 25, 2010 01:22 |  #4
Hey, guys, just get the 7D or for a budget the 50D. There is no sense in going full frame until you know that you really want it.
Tony
andylo
Sep 25, 2010 01:24 |  #5
Being converted from 1.6x -> 1.3x. I think it's better to get a bigger sensor camera than go for a crop just because of more reach.
To me a bigger sensor's major advantage is not getting wider. But the fact how well the high ISO performance actually is, and I am talking about a huge difference anyone can see. Same as one can always buy a 8-16 sigma to go wide, one can also buy a 150-500 OS or the new 50-500 OS anyway. But the high ISO performance is build-in and is not able to replace.
I will go for a 5D in your case, and if I need a longer reach, the 150-500 OS is not that expensive anyway.
Andy
Canon 1DX/1DMKIII :: Canon 8-15mm f/4 L :: Canon 24-70mm f/2.8L :: Canon 17-40mm f/4L :: Canon 100mm IS f/2.8L :: Canon 70-200mm IS f/2.8L MKII :: Canon 50mm f/1.2L :: Tripodo GX-1227 carbon tripod :: Manfrotto Monopod
darosk
Sep 25, 2010 01:26 |  #6
I agree with Tony. If you're asking the 5DII vs 7D question, then the answer is the 7D... or even something cheaper. Pocket the $1000 price difference. Or better yet, blow it on a nice lens, maybe an L like the 135L.
Tumblr (external link) | Facebook (external link) | Youtube (external link)
Gear
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Sep 25, 2010 01:27 as a reply to  @ Staszek's post |  #7
I would agree, the biggest difference is the depth of field.
However, I don't think the same composed shots with similar lenses would suck b/c one was on a cropped sensor and another was with a full frame.
Depth of field control is nicer, but like resolution, noise, and all that, none of those make for a good image on it's own. Composition, timing, exposure, and proper processing makes the most impact IMO.
Having said that, a 35mm format gives a nicer shooting experience. Hard to describe but it is nicer, at least for me it is.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Deep ­ Pocket
Sep 25, 2010 01:30 |  #8
It's impossible to find a new 5D, correct? I've just had bad luck last time I bought used
and I would have to replace ALL my lenses :(
17 and learning..
drive_75
Sep 25, 2010 01:31 |  #9
How much dramatic different between the two camera should be decide by you. It's dramatically different for me but how do I know it's dramatic for you? Beside, you said you can't afford 5D2 and you won't buy use so the answer should be obvious for you.
Honestly, my suggestion is to buy the camera you can afford and let that be the end of it. I think you would be happy with either 7D or 50D given if you stop wondering how much better the other camera that you don't have compare to the one you have.
Todd ­ Lambert
I don't like titles
Sep 25, 2010 01:31 |  #10
Yes
tonylong
...winded
Gallery: 60 photos
Sep 25, 2010 01:36 |  #11
If you can get the 5DC for ~$1k it's good, but I wouldn't give up a crop body for it unless you really knew what you are doing. If you don't, keep shooting crop!
Tony
NatDeroxL7
Sep 25, 2010 04:37 |  #12
Sounds like 7D is the right one for you!
https://www.instagram.​com/nd14411 (external link)
https://natedphoto.myp​ortfolio.com/ (external link)
Enrico81
Sep 25, 2010 05:16 |  #13
I have the same doubt...and now I don't know what to do...
I have 5d old, and recently I took a sigma 50mm 1.4...I love it... but I miss the technology of 7d or 5d mkII... I really don't know what to do...7d for 1000 euros or 5d mk II for 1600 euros (both brand new)?
I like portraits, and I think my ideal range is 35mm - 120mm...so probably 7d + 24-70mm 2.8 or 35 f 2 + 50mm 1.4 and 100mm L on 5d mk II...
philwillmedia
Sep 25, 2010 05:24 |  #14
Isn't this the same question as this active thread https://photography-on-the.net/forum/showthre​ad.php?t=934109
Or am I missing something?
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
k-lo
Sep 25, 2010 05:31 |  #15
i wouldn't say it's dramatically better, FF images sometimes have a distinct look and feel.
-=Karlo=- 1D III, 5D Mark II, 17-40 4 L, 35 1.4 L 24-70 2.8 L, 135mm 2.0 L, 85mm 1.2 L II, 300mm f 2.8 L, 580EX II, and a crapload of Elinchrom Gear :cool:
View my flickr sets (external link)
Check out my Modelmayhem port (external link)
500px (external link)
85,941 views & 0 likes for this thread, 167 members have posted to it.
2294 guests, 121 members online
