I built a PC with an i7-930, ASUS P6X58D-E Mobo and Kingston DDR3 RAM. The computer has been working flawlessly but I did notice that the DRAM frequency is 1066 instead of 1600 for my Kingston RAM (KHX1600C8D3K3/6GX).
I'm not really looking to OC the PC, but was wondering if I should manually select 1600 DRAM frequency in the BIOS in the "AI Tweaker Menu". Also, if I do should I let the voltage be selected automatically or does it need to be manually set?
Also, what's considered to be a "very high DRAM frequency" that would cause the system to be unstable?
Is there anything else I need to do or watch out for?
Temperatures are really low and the system stability seems perfect, at least no different that before I made the change.
