itzcryptic wrote in post #11020318
The reason why is because the area of the sensor is larger on the FF cameras, so each photosite/pixel can be larger and collect more light. More light means a better signal to noise ratio.
True. And if you compare like for like in terms of technological development, the difference is a bit over one stop. This is just as you would expect, as full frame is a bit over twice the area of crop format - 2.56x larger actually, 1.6x1.6=2.56.
The effective difference is a bit more than that, becuase despite 'gap-less' microlenses they are not actually gapless and the gaps on crop sensors take up relatively more sensor area.
The other big advanatge of full frame is sharpness, regardless of pixel count (which is a bit of a red herring TBH). There are two aspects to sharpness - resolution and contrast. Those are the two axes of an MTF graph and the fact of physics is that as resolution goes up, so contrast goes down, and it is actually contrast that makes the biggest contribution to the visual impression of sharpness.
Since full frame asks a lot less of the lens in order to deliver the same ultimate output resolution, the full frame image will always have higher contrast and more pop.
5D2, 17-40L, 50/1.8, 24-105L, 70-200L 4 IS, 580/270EX, Strato II/RF-602, Elinchroms
