Thread started 02 Oct 2010 (Saturday) 15:55
iris: sharpening CC
jetcode
Oct 02, 2010 15:55 |  #1
bannedPermanently
I find that sharpening is a bit of a losing battle between fidelity and acutance. Any other CC welcome. Joe
corkneyfonz
Oct 02, 2010 21:00 |  #2
Fabulous interpretation as usual.
My Flickr (external link)
jetcode
Oct 02, 2010 22:26 |  #3
bannedPermanently
It's not a bit overcooked on the unfolded iris? I think more of the white noise needs to disappear and I am thinking my sharpening technique needs to go to the next level.
L.J.G.
"Not brigth enough"
Oct 02, 2010 22:28 |  #4
It almost looks 3D on my screen, it is very well done.
Lloyd
Never make the same mistake twice, there are so many new ones, try a different one each day
Gear Flick (external link)r
argyle
Oct 03, 2010 06:27 as a reply to  @ L.J.G.'s post |  #5
Are you using solely USM for your sharpening? You may want to take a look at a plug-in called Photokit Sharpener. I've been using this religiously for the past few years. This has three sharpening levels available: Capture Sharpening, Creative Sharpening, and Output Sharpening. Capture is used to override the initial effects of the AA filter, Creative can be used for fine-tuning specific areas of the image, and Output enables the sharpening to be custom-tailored to the output type and output method (e.g., contone printing, inkjet printing, web-based images, etc.). Each sharpening type creates a separate layer which can be easily adjusted with the opacity slider. The best thing is, you don't need to use all three sharpening types on an image...you simply use what you need. The plug-in also includes a haze cutting application. Probably the best $95 you could spend on software enhancement.
jetcode
Oct 03, 2010 13:02 |  #6
bannedPermanently
argyle I use a combination of techniques including USM (output mostly), DP capture sharpening, local and global high pass and edge sharpening processes in CF. I miss 4x5. The detail is the sharpness not exclusively the edge itself. I assume that since I haven't caught a lot of flack for this image that this level of sharpening is acceptable. Personally I wish there was more dynamic tone in the sharpened areas.
1,180 views & 0 likes for this thread, 4 members have posted to it.
iris: sharpening CC
1340 guests, 179 members online
