Thread started 03 Oct 2010 (Sunday) 14:12
Use of Flash in Shade
Peacefield
Oct 03, 2010 14:12 |  #1
Sometimes I'll use off-camera flash in shade just to add a little depth to the image, but that's NOT what I'm asking about here.
I've had some instances where I was shooting in harsh full sun, found the shade of a tree and did portraits there. The problem was that the area in the background was so bright that it overpowers the subject in the photo. If it's not possible to move to an angle so as to avoid that bright background, how do you handle this? Do you maybe meter on the area in full sun and use flash on the subject to bring them up to the same brightness? Or do you just shoot the scene and it is what it is?
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
david ­ lee
Oct 03, 2010 14:22 |  #2
Depends if its a nice background and whether I want to have any part of it in my photo.
But assuming you want to have BG in Expose for a mid bright area and then underexpose by about 2 stops. Use OCF set to ETTL to fill in foreground
davidleeimages.co.uk (external link)
pbase (external link)
gear
"My fingers hurt from taking too many photos" D.A.Lee LBIPP
Valjoy
Oct 03, 2010 17:00 |  #3
Very good question...I am also interested to see how others handle this situations.
EL_PIC
Oct 03, 2010 17:41 |  #4
Valjoy wrote in post #11026467 (external link)
Use PS to mask the front image from back then adjust the background only
or - delete the background and sub in another shot of it at normal exposure.
EL_PIC - RIT BS Photo '78 - Photomask Engineering Mgr
Canon DSLR - Nikon SLR - Phase One 60MP MFDSLR
http://www.Photo-Image-Creations.com (external link)
http://www.musecube.co​m/el_pic/ (external link)
http://www.facebook.co​m/PhotoImageCreations (external link)
Bansheercr
Oct 03, 2010 19:33 as a reply to  @ EL_PIC's post |  #5
I've exposed for the background then let the flash fill in the subject with good results. Don't see how you can have the best of both worlds naturally. Perhaps catching some sun with a reflector would help in the shade other wise ps editing.
PMCphotography
Joined Sep 2009
Oct 03, 2010 20:29 |  #6
Either expose for the background and fill flash for the foreground, or use a tripod and take 2 separate exposures, one for the couple and one for the background, then combine in PhotoShop. Is also do one without flash- sometimes the blowout background makes a nice image.
Twitter (external link)
Hobart Wedding Photography (external link)
I have some camera stuff. Here it is.
css7493
Oct 03, 2010 23:59 as a reply to  @ PMCphotography's post |  #7
I shoot with 1-2 580s OCF almost all the time, this exact situation. Set the flash at an angle with respect to shadowfall on any tree trunk or wall they are near. I oftentimes use OCF even out of the shade to better underexpose the sky and get better colors from it.
Gear
tim
Light Bringer
Oct 04, 2010 00:04 |  #8
I wouldn't put people in the shade if the background is bright, i'd put them in shade which has a solid background, like a bush.
If there's nowhere like that i'd keep people in the sun, back to the sun, and use off camera flash to light them.
If it was really, really hot, i'd put them in the shade and use off camera flash to try to make them as bright as the background.
You can always blow out the background, of course, but that reduces contrast.
Peacefield
Oct 04, 2010 07:24 |  #9
tim wrote in post #11028827 (external link)
Yeah, I'm not a fan of blown out background for group shots for this reason. And simply bringing them into the sun and using fill flash is a good and obvious solution that just wasn't coming to me; thanks.
Acute ­ Exposure
Oct 04, 2010 07:26 |  #10
I use a reflector to accomplish this. It is nearly as bright as the sunlit background but it is much more diffuse as I use a large one and only the white side.
Website (Updated Recently) (external link)
Flickr (Constantly Updated) (external link)
Canon 1Ds3 - 7D - 24-105mm F4 L IS - 70-200mm F2.8 L IS II (Always attached) - 50mm 1.8 (Never gets used) - 1.4x MKii - 580EX II - 430EX II - Lots of other gadgets
viet
Oct 05, 2010 03:03 |  #11
if you can't avoid it, bring them back out in the sun behind their back and fill in with flash. If you balance the faces with the backlit sun in the shade, it'll look obviously flash was used since the shaded area immediately behind them will still not lit enough to balance things out. Hard to explain, but the gis of it is you will get different & high contrast light ratios, and your subjects will look "flashed".
Bringing them back out to the sun, you only have to worry about their faces and not the surrounding area.
edit: I should read more before answering. Tim beat me to it.
tim
Light Bringer
Oct 05, 2010 03:05 |  #12
OneFastt996 wrote in post #11030245 (external link)
Reflectors make people squint. Flash, with a short duration, is nicer for people though less bright. And you can't easily light more than about 3 people with a reflector.
Acute ­ Exposure
Oct 05, 2010 03:50 |  #13
tim wrote in post #11036437 (external link)
That is somewhat true. The white side off at an angle with a fill flash to fill the darker side eliminates squint and allows you to shoot for the bright background. I have found this very effective.
picturecrazy
soft-hearted weenie-boy
Oct 05, 2010 09:29 |  #14
I'm with Tim. Even white reflectors make people squint. People have called it a "torture device" during shoots... which is one of the many reasons I stopped using reflectors. Otherwise, in a technical sense, they are quite effective. I now only use them as scrims.
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
Shockey
Oct 05, 2010 09:41 |  #15
Several different ways.
Shoot them without flash and let the background go, or light flash to get better color and let the background go.
I would shoot them in the sun, and expose for the face, save the background or let it go...either way works...depends on what you are going for.
That silly rule about not shooting people in the sun is more for beginners. Once you learn to shoot in the sun, just do it. I would rather shoot in the sun than in that green shady light, I call that light "green death" haha.....especially if you are not using a flash.
___________
Boise Portrait Photographer
www.alloutdoor.smugmug​.com (external link)
www.aoboudoirboise.smu​gmug.com (external link)
7,944 views & 0 likes for this thread, 19 members have posted to it.
1592 guests, 137 members online
