Thread started 03 Oct 2010 (Sunday) 20:06
Polar alignment scope for a barn door tracker?
Badger49456
Oct 03, 2010 20:06 |  #1
I'm writing down parts I need to build a barn door tracker, and I'm stuck on the polar alignment scope. I'm not sure what to use. I want something a little more accurate than a straw :lol:
Should I get a polar alignment scope like this one from Orion (external link) (but it's not illuminated, hmm...), or something like a right angle illuminated finder scope? Preferably it'd have a reticle with markings at known degrees so I could find Polaris and then get as close as possible to the celestial pole.
Any suggestions?
MintMark
Oct 04, 2010 06:22 |  #2
Badger49456 wrote in post #11027370 (external link)
Any suggestions?
A straw is far too small an aperture... you need a larger tube with home made cross hairs on the end :)
I've never made a barn door tracker but I do have an astrotrac, so same principles.
I think the answer to your question will come from thinking about how you intend to mount it on your tracker. Will you have a way of adjusting the collimation of the polar scope with the hinge of the tracker? How accurate will it be? Something like a finder scope mount with three screws would be good.
Then how much play is there in the hinge? No point having super accurate polar alignment if the hinge can wobble from side to side.
Finally, if you're only doing wide field then it doesn't have to be very accurate, but of course the more accurate it is the more you can do with it.
Sorry I don't have an answer, but just some things to think about.
Mark
martyn_bannister
Oct 04, 2010 12:36 |  #3
Any suggestions?
Cheap air-rifle sighting scope perhaps? I have been looking at using a green laser for my barndoor project (currently stalled :() but I know that a lot of people don't like lasers.
the ­ jimmy
Oct 09, 2010 15:49 |  #4
Any suggestions?
Are the plans for this barn door tracker available online? I would be interested in seeing them.
It seems the hinge is an important component in this build, and the rifle scope could be the way to go.
martyn_bannister
Oct 10, 2010 05:16 |  #5
the jimmy wrote in post #11064898 (external link)
You might find THIS (external link) interesting.
Badger49456
Oct 10, 2010 14:37 |  #6
Thanks for all the suggestions. I think I do have an air rifle scope around, and that should be good enough to play around with at first, at least to get the feel of doing it a few time.
I'm going to try to emulate Gary Seronik's plans availabe here http://www.garyseronik​.com/?q=node/52 (external link) I like the compactness of his and it looks fairly straightforward.
the ­ jimmy
Oct 11, 2010 11:15 |  #7
Badger49456 wrote in post #11069438 (external link)
Thanks for the link, that's a cool looking tracker compared to others I've see on the web. I would have to belive the alinement of the hinge is important, and having two of them might add to the possibility of error, or maybe I am over rating this...
Badger49456
Oct 11, 2010 16:49 |  #8
the jimmy wrote in post #11075265 (external link)
Well you might be right, and I've thought about that and simply using a single 6" hinge. I just ordered the motor and gears today so hopefully I'll have something to share in the coming weeks!
Adrena1in
Oct 19, 2010 07:53 |  #9
martyn_bannister wrote in post #11031927 (external link)
You've not seen mine yet have you Martyn? Excellent for pointing out things in the sky, but produces a blindingly bright dot when shone on the ground or a surface. And it's only a 20mW one as well. So yeah, not really a very good idea. Plus when it gets quite cold it hardly works at all.
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
martyn_bannister
Oct 19, 2010 13:10 |  #10
Adrena1in wrote in post #11124663 (external link)
Not yet, no :) But I'm hoping to get out at some time in the next six months. I have bought a laser for my project, but hardly dare take it out :)
8,855 views & 0 likes for this thread, 5 members have posted to it.
1370 guests, 188 members online
