Thread started 04 Oct 2010 (Monday) 13:57
70-200mm 2.8 NON-IS Bayonet Repair Question
sabianq
Oct 04, 2010 13:57 |  #1
hi all..
well, long story short..
i purchased a used 70-200mm 2.8 NON-IS a couple of weeks ago.
There is some rotational play in the lens/body connection.
upon closer inspection, it is aparent that the locking hole where the pin from the body inserts into the lens is worn causing the play in rotation.
The rear Bayonet Mount needs to be/should be replaced.
So i contacted Canon tech and discussed the issue.
apparently, my suspitions about heavier lenses causing wear at this point in the camera body to lens connection are valid.
(a heavy lens can cause wear at the bayonet maount.
since the lens is out of warranty i can do the replacement myself.
the part number for the bayonet mount is CY1-2497-000-xxx
the (xxx) number on the part number is a measurement that describes the thickness of the bayonet mount. and that thickness comes in a range
from 1.5mm to 2.8mm in 1/10 mm increments.
i was told by canon that i have to remove the bayonet ring and measure the thickness to determine the replacement part number..
not a problem.
anyway, i have to wonder if that thickness affects the back/front focus of the lens.
Why would there be such a range in thickness for a standard production lens?
Does anybody have any insight into the raminifactions of changing the distance (via bayonet thickness) of the lens element to the sensor?
I am thinking about sending the lens to Canon for a calibration.
does anybody have a suggestion as to me either have canon replace the ring when i send it in or if i should replace the ringn before i send it in.
on a side note,
when i looked for the ring online, there is an EBAY seller selling the ring for $125.00 bucks.
when I contacted Canon Parts (1 866 481-2569) i was quoted the price of the mount at $31.77
thanks fo your insight!
cheers!
Enjoy the Silence, it does not come very often...
Brian Larson
Datsbrian@Gmail.com (external link)
(Creative Solutions & Paradox pix) (external link)
ben_r_
-POTN's Three legged Support-
Oct 04, 2010 15:52 |  #2
Cant Canon just send you the same one the lens shipped with? Perhaps they can reference it via serial number?
msowsun
Gallery: 14 photos
Oct 04, 2010 18:15 |  #3
I have seen this in the parts diagrams and always assumed that the mount is how they fine tune the front/back focus on a lens. I wouldn't want to try and use a different size from what was originally installed.
I would let Canon replace the mount. They sometimes do a repair like this for free, even outside the warranty period.
This is from the 50mm 1.4
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/Photo4/_1shim.jpg
Mike Sowsun / S110 / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 18-135mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 1.4x II
sabianq
Oct 04, 2010 23:23 |  #4
i would think that you are correct.
i have a football game to shoot on friday then i might need the camera for the weekend.
on monday im gonna send in both the body and the lens.
the body is only 3 months old but has banding issues in the red pixels at high ISO (3200 and above)
there is also 3 bright red pixels in the field. they said they can be "re mapped" and the banding issues should not be there..
id be happy to spend some cash to get the lens back to factory spec.
Brian Larson
RL.
Oct 04, 2010 23:34 |  #5
interesting I also thought that my 70-200 might cause strain on the mount but I hoped it wouldnt...guess i have to be more careful
Canon > Nikon
sabianq
Oct 05, 2010 00:45 |  #6
here are some photos
Brian Larson
sabianq
Oct 05, 2010 00:59 |  #7
thanks for that very useful information mike.
Cheers!
Brian Larson
philwillmedia
Oct 05, 2010 05:42 |  #8
I wouldn't worry too much, that's normal.
All my lenses, both "L" and non "L", show some wear like that and have a small amount of rotational play.
I've never found it to affect image IQ.
The only thing I would be concerned about is if the lens is not locking into place.
Regards, Phil
2013/14 CAMS Gold Accredited Photographer | 2010 & 2011 V8 Supercars Aust. Accredited Photographer | 2008, '09, '10 South Aus. Rally Photographer of the Year | Catch Fence Photos - 2009 Photo of the Year (external link)Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office" | www.freewebs.com/philw​illmedia (external link)
Lacks_focus
Oct 05, 2010 05:56 |  #9
philwillmedia wrote in post #11036833 (external link)
A big ditto. They all have some play. I just looked my 70-200’s mount. It looks just like yours. No issues... It would have to be pretty severe, like the pins not able to make proper contact sever, for this to ever be a problem. I think all you will accomplish by sending it in is a cleaning and calibration. If you need that, cool, go for it, but I wouldn’t send it in if all it needed was this mount addressed. You will very likely still see some play, less yes, but soon it will be right back to where it is now.
1D MKIII | FujiFilm X10 | 24-70 f/2.8 | 70-200 f/2.8 | 135 f/2 | 85 f/1.8 | 580EX |
lacks-focus.smugmug.com (external link)
ben_r_
Oct 05, 2010 11:37 |  #10
Wow, thats crazy! NONE of my lenses have any play that I have ever noticed. They really shouldnt. There should never at any time be the entire weight of the lens on the camera body. You always hold the camera by the lens which takes the weight off the camera or use a tripod ring mount which also takes the weight off the camera. After several years, all my lens mounts look EXACTLY as they did when they were brand new.
msowsun
Gallery: 14 photos
Oct 05, 2010 11:50 |  #11
I don't understand how the weight of the lens would have any factor in wear on the locking pin hole.
Can someone explain that?
ben_r_
Oct 05, 2010 12:00 |  #12
msowsun wrote in post #11038575 (external link)
I was kinda wondering that too, but I was taking their word for it...
jra
Oct 05, 2010 13:00 |  #13
My 70-200 has had a bit of play in it since brand new (along with some of my other lenses). As long as it locks in, a small amount of play seems to be normal and shouldn't affect IQ.
johnf3f
Oct 05, 2010 17:03 |  #14
Got and used a number of Canon cameras and normal + L lenses ( currently got 5 L's and two normal), the ONLY combinations I ever had that fitted perfectly were the EOS IX7 and 500n with the 50mm F1.8 ii - all PLASTIC MOUNTS!
Life is for living, cameras are to capture it (one day I will learn how!).
joeseph
"smells like turd"
Gallery: 137 photos
Joined Jan 2004
Oct 05, 2010 17:22 |  #15
best I can come up with is the inertia of the twisting motion (mounting the lens) is greater when the lens is heavier and results in more force being applied when the pin clicks in and stops the lens rotating further.
I'm very dubious that in reality it'll cause increased 'wear" though, and assumes the lens is mounted on the body & not the other way around. Does the pin actually stop the lens rotating further? Guess we could test by holding the release button in and see if it moves further round...
Had a look at my 70-200 and 100-400 and they both look similar to pics posted above. So does my 16-35.
On a side note, the 1.4x TX has an "insert" around the locking pinhole - wonder if they found problems at some stage and use a harder material to overcome it.
some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", 1D MK II converted for IR, and now an M5
TF posting: here :-)
15,094 views & 0 likes for this thread
Latest registered member is umerbilal
1093 guests, 225 members online
