Thread started 05 Oct 2010 (Tuesday) 19:48
Please help me with editing my first headshot session
Drakeskakes
Oct 05, 2010 19:48 |  #1
This guy is an opera singer, and needs some very professional and "formal" head shots.
I've never edited before, and my partner did the shooting. How is this for a head shot edit/
Please note that I am by nature a High-Contrast, love blacks and gritty looks type of post processor so I'm having serious withdrawal having to be conservative.
Is it to flat?
To grey?
Yes his eyes are naturally different.
"Nobodys built like you....
.... You design yourself"
www.NeillDrake.com (external link)
Gripped 50D | 17-55 2.8 IS USM | Sigma 10mm 2.8 Fisheye | 100mm 2.8 Macro USM | Nifty Fifty | 430ex II | Timbuk2
pcj
Oct 05, 2010 20:16 |  #2
For my mind, the crop makes his head feel small - he's clearly a bigger bodied guy - what about a crop that trims out his chest and the dead space above and around his face and gets much tighter on him?
7D (gripped) | GoPro Hero HD | Canon 70-200mm f/4 L | Tamron 28-75mm f/2.8 | 40mm f/2.8 | 85mm f/1.8 | 28mm f/1.8 | 3 * 600EX-RT - All gear
http://www.rt2photo.co​m (external link)
http://www.facebook.co​m/rt2photo (external link)
JackStrutz
Oct 05, 2010 20:57 |  #3
Agreed. The crop is no bien. You definitely need a bit more contrast.
Gear | Flickr (external link)
Drakeskakes
Oct 05, 2010 21:52 |  #4
Do you think it looks a bit yearbookish?
Damian75
Oct 05, 2010 21:57 |  #5
Took a quick shot at it. Could probably get a better B&W conversion from the color image.
Canon EOS 40D,30D, Canon 70-200 2.8L, 24-70 2.8L, 85 1.8, Canon extension tube, Elinchrom Lighting gear, 
Website (external link)
Drakeskakes
Oct 05, 2010 22:00 as a reply to  @ JackStrutz's post |  #6
Hows this one, a little better?
JackStrutz
Oct 05, 2010 22:31 |  #7
The second one is much better. The B&W is still a little bit bland though.
Drakeskakes
Oct 05, 2010 23:06 |  #8
Do you suggest just + contrast or do a + exposure + blacks and a hint of fill light to bring back lost detail in jacket and the hair?
JackStrutz
Oct 06, 2010 00:06 |  #9
Post them in color so we can get a better feel of how the original looked
PixelMagic
Oct 06, 2010 04:35 |  #10
Drakeskakes wrote in post #11041350 (external link)
Can you tolerate an honest critique?
In my opinion these are neither professional nor formal. Rather than waste time trying to edit these photos I would offer a reshoot.
1. The camera was positioned much lower than the subject's face resulting in "up the nose" shots which are never flattering. No amount of editing can fix that; the camera needs to be positioned at the appropriate height.
2. This is related to the first problem. Since the camera was low it was tilted to capture the subject's face which resulted in a shift in the plane of focus. You can see this clearly where the tie knot is sharply in focus and the subject's face is slightly out of focus.
3. A 35mm lens is categorized as a wide angle lens. To get more flattering shots you need to use a longer focal length lens....85mm to 135mm is considered the norm for portraiture depending on the amount of working space available. A wide angle lens can be used in a pinch but its likely to introduce distortions.
I'd strongly suggest you Google the word "headshots" and take a look at how they are typically done. Here's one informative website: Headshots 101 (external link)
Notice that there are no "up the nose" shots.
Is it to flat?
To grey?
Its not clear how you're converting to B&W but I'd say the answer to your question is "yes." And even at this small size there's visible luma noise on his suit jacket.
Drakeskakes
Oct 06, 2010 08:23 |  #11
PixelMagic wrote in post #11043750 (external link)
Absolutely, thats the only way to get better, so thank you
Like mentioned earlier, I didn't do the actual shooting. The clients exact words were "They need to be very straight on, no angles or anything" My partner did however, after a few test fires sit on the backing of a chair while shooting, and I think its a combination of him looking up, and naturally being large nostrilled, but heres a few I think might be better
I probably grabbed one of the bad examples, heres 2 I think are a little better.
the 35mm was used for only a short moment, the rest of the shoot was done with a 70-200 2.8 IS
Theres a few different ways i've been playing with. Lightroom 3.2 has a bunch of presets, but these are all pretty much just done using the supersaturation slider in LR. I also think is has to do with photoshop not letting me save a max 1024 side image any less than a quality of 3, to keep it under 150k
I appreciate your critique, honestly. Heres 2 color ones. These are SOOC except cropped 8x10 but not tightened and converted to jpeg
IMAGE: http://img.photobucket.com/albums/v134/Drakeskakes/IMG_7980-Edit.jpg
IMAGE: http://img.photobucket.com/albums/v134/Drakeskakes/IMG_7966-Edit-1.jpg
enrigonz
Oct 06, 2010 08:31 |  #12
Drakeskakes wrote in post #11042175 (external link)
I like the second one also but I would work the lighting a little, if you took a RAW image (which I hope you did) you can increase the exposure 1-2 stops and see what becomes. Also clone the wall molding coming out from the back of his head on that second shot. Try doing the monochrome conversion in RAW after you crop and make all the adjustments in Canon's DPP software, I get much better results there than I do in any other program.
Canon Stuff :) |Flickr (external link) | Facebook (external link)
Drakeskakes
Oct 06, 2010 08:35 |  #13
enrigonz wrote in post #11044435 (external link)
Yeah I always clone out the lines =)
Thanks, I'll try using DPP! I've been using either lightrooms saturation slider or CS5's black and white converter
2,498 views & 0 likes for this thread, 6 members have posted to it.
1122 guests, 171 members online
