i know that straps should be connected to the lens instead of the cam body ...
what do you guys use?
blackrapid on the tripod mount or weight reduction strap like op tech on the lens?
mikecabilangan Goldmember 1,378 posts Joined Apr 2010 Location: Metro Manila More info | Oct 05, 2010 21:47 | #1 i know that straps should be connected to the lens instead of the cam body ... camera bag reviews
RogerC11 Senior Member 467 posts Likes: 3 Joined Aug 2010 More info | Oct 05, 2010 22:09 | #2 mike cabilangan wrote in post #11042084 i know that straps should be connected to the lens instead of the cam body ... what do you guys use? blackrapid on the tripod mount or weight reduction strap like op tech on the lens? blackrapid on the lens.
Pearlallica Goldmember 1,303 posts Joined Aug 2008 Location: Great White North More info | Oct 05, 2010 22:13 | #3 also blackrapid on the lens. jonathan @ tlcphoto.com
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Oct 05, 2010 22:41 | #4 Which tele? Fuji XT-1, 18-55mm
Oct 05, 2010 22:52 | #5 200 f/2 camera bag reviews
KenNielsen Goldmember 1,510 posts Likes: 2 Joined Jun 2004 Location: Portland OR More info | Oct 05, 2010 23:12 | #6 I never use a strap but a customized over the shoulder binocular bag with the bottom knocked out and sleeve sewn on like a wind sock that folds back up to accommodate the length of the lens I am using. This takes the weight completely off and allows me to use the camera strap around my neck with no weight pulling on me, just as a safety precaution. It has taken me two years to devise this shoulder carrying system based on my own build and comfort points. The camera and lens now 'float' under my left arm and I can pull that baby out in an instant and start shooting (It works like a shoulder holster for a magnum .45)
AndersÖstberg Goldmember 3,395 posts Likes: 3 Joined Nov 2003 Location: Sweden More info | Oct 05, 2010 23:28 | #7 Upstrap ... with a second set of female strap ends on the lens so I can move the shoulder strap from the camera to the lens when using the tele. Anders Östberg - Mostly Canon gear - My photos
P51Mstg Goldmember 1,336 posts Likes: 2 Joined Feb 2007 Location: Mt. Carmel, TN More info | I use the same combo as Anders, UPSTRAP with extra ends on the lens..... Too Much Camera Stuff......
Oct 06, 2010 00:31 | #9 P51Mstg wrote in post #11042904 If you need another strap on a 200 2.0 (I've got a 200 1.8 ). you need to reexamine your shooting style.... i didn't get this one ... can you run that by me again? camera bag reviews
b_ron Senior Member 547 posts Joined Oct 2009 Location: sOCal More info | Oct 06, 2010 01:29 | #10 mike cabilangan wrote in post #11043075 i didn't get this one ... can you run that by me again? Basically: Do you really need a strap for that lens...?
AndersÖstberg Goldmember 3,395 posts Likes: 3 Joined Nov 2003 Location: Sweden More info | Oct 06, 2010 01:33 | #11 If the lens has strap mounts I guess Canon thinks it's too heavy to be carried around hanging from the lens mount? Anders Östberg - Mostly Canon gear - My photos
Oct 06, 2010 01:50 | #12 b_ron wrote in post #11043274 Basically: Do you really need a strap for that lens...? yes i do. camera bag reviews
P51Mstg Goldmember 1,336 posts Likes: 2 Joined Feb 2007 Location: Mt. Carmel, TN More info | The 200 is a bit smaller than the 300 and a fair (or so it feels) lot lighter. The lenses BOTH handle (move, etc) better with a strap on the body of the camera rather than one on the lens itself (at least for me).... Too Much Camera Stuff......
Oct 06, 2010 20:51 | #14 found the sun sniper online (local distro wasn't answering their phones) i'll buy a set to check it out. (cheaper than black rapid) camera bag reviews
r.morales Goldmember 2,296 posts Joined Apr 2007 Location: Bay Area Calif More info | Oct 06, 2010 21:09 | #15 I use the bogen on my 35-350 when on tripod .
| Latest registered member is zachary24 1401 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
