Don't worry about 'not enough light' until (assuming ISO 400) your subjects are out more than 40' and your flash AOV coverage is for a 'normal' lens or WA.
From your confusion, it seems you are running a bit short on familiarity with flash in the situation you described. Getting it right 'after a few test shots' is OK for shooting a series of portraits (all subjects standing same distance from flash), but unless you have ETTL or a good command of flash exposure according to Guide Number arithmetic, at fast paced events with variety of flash distances you will likely flounder. (Those of us who are experienced with flash before Auto flash even existed had developed techniques to deal rapidly even without flash meters...today's shooters would be lost, for the most part, just as so many cannot drive a manual transmission car.)
'Small groups' I presume to refer to 6 people groups? If so, no problem. Larger groups spread over a wider area, the technique of 'feathering' the light on the closest person (to prevent overexposure of that person while also underexposing the farthest person in the group) should be kept in mind.
