Thread started 08 Oct 2010 (Friday) 19:38
Newb to using flash questions
MKerckaert
Oct 08, 2010 19:38 |  #1
So I finally broke down and bought a couple Vivitar 285HV flashes and a basic trigger/receiver set off of ebay. This: http://cgi.ebay.com …20678723500#ht_​3081wt_980 (external link) but with 4 receivers.
I'm trying hard to figure out how to use it. First I just attach the flash directly to the camera and when the flash goes off, only the top half of each photo had the flash in it and the bottom have was completely black.
So then I attach the transmitter to the camera and the receiver to one of the flashes on a tripod. Nothing happens.
Is there something that i'm missing? I'm so new to this to forgive me for how lame this post is. Thanks!!
-Mark
My Gear: Camera // Lenses // Stuff
markusrichmond.com (external link)Flickr (external link)Blog (external link)
PacAce
Joined Feb 2003
Oct 08, 2010 19:43 |  #2
Make sure that your shutter speed is set to 1/200 or slower and try it again.
...Leo
Green ­ Li
Gallery: 15 photos
Oct 08, 2010 20:01 |  #3
PacAce wrote in post #11060980 (external link)
exactly. looks like the shutter speed at least one of the problems.
PHOTO-TIPS-ONLINE.com – photo tips, photography reviews (external link)
Facebook (external link) | Twitter (external link) | Google (external link)+
MKerckaert
Oct 08, 2010 20:01 |  #4
Cool thanks, I'm sure that was the problem with my first issue. But what about the receivers?
-Mark
PacAce
Joined Feb 2003
Oct 08, 2010 20:18 |  #5
MKerckaert wrote in post #11061065 (external link)
Make sure that the shutter speed is correct first. The receiver issue might be related, i.e. the shutter being too fast for the receiver also.
...Leo
ponzy
Oct 08, 2010 20:28 |  #6
@ mark, mind you tell me what body do you use? im considering those wireless triggers, with rf602's tho, but ive read some are succesfull nand some are not with max sync speed of 1/250s without banding
ponzy
"The thing I hate the most is when the light is in control. The key to good lighting is to be in control of the light." by ROB ~TMR DESIGN~
nes_matt
Oct 08, 2010 22:06 |  #7
ponzy wrote in post #11061189 (external link)
I tested my rf602's last week at 1/250 and could just make out a shadow at the bottom, but none at 1/200. I wouldn't rely on getting 1/250th. some claim battery choice pushes them over the edge to get it.
Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
Flickr photo stream (external link)
Portfolio (external link)
Facebook Page (external link)
nes_matt
Oct 08, 2010 22:10 |  #8
MKerckaert wrote in post #11060956 (external link)
I had the same problem, but I figured out what I was doing: I was taking too long! I was fooling around getting things set up and my flash was shutting itself down while I was moving stuff, checking settings, etc. Not sure if it's your issue, but it definitely was mine.
Try just pressing the button on the remote to see if you can get it to flash without the camera. If not, check the dip switch settings to make sure the addresses are set the same. Also, make sure none of the batteries are in backwards.
vinmunoz
Gallery: 444 photos
Oct 09, 2010 12:31 |  #9
I guessed your triggers are not TTL(Through The Lens). Most triggers at those price range are not TTL. I checked your ebay link and had verified that it's not TTL.
| SONY A7SIII(2) | A73 | A6000 | Sony A7IV | Sigma105 | FE1635F4 | Tamron 70-180mm F2.8 | Tamron 17-28 Tamron 28-75 | FE50F1.8 | Sony 16035F4PZ | SEL30mm F3.5 Macro | Canon 24mm TSE | Laowa 15mm Shift
INSTAGRAM (external link)- WEBSITE (external link) - FACEBOOK (external link) - 500PX (external link)
ukcyberboy
Oct 09, 2010 14:26 |  #10
I have just done a quick speed test
1/250 no band, 1/320 has a band at bottom upto 1/5, 1/400 has band upto 2/5 , 1/500 has band up to 3/5. It is surprising how much of the image is correctly exposed.
I regularly use the 1,250 so I can use a longer length on my f4L.
Simon
Body | Canon 6D |
Lens | Yongnuo 50mm 1.8 |
Lens | Canon 28-70 2.8 L |
Lens | Canon 70-200is F4 L |
Lighting | Yongnuo YN600RX |
Accessories | Various Bits |​
MKerckaert
Oct 09, 2010 16:46 |  #11
I'm just using an old 350D.
-Mark
MKerckaert
Oct 12, 2010 17:01 |  #12
Does anybody have any idea what this could be?? Maybe the batteries in the units are useless? I've already figured out the shutter speed issue.
-Mark
klr.b
Oct 12, 2010 18:05 |  #13
never trust the supplied batteries. i get batteries with 1/2 charge to fully dead sometimes. you don't know how long they've just been sitting there. go out and buy some new batteries.
gordon
Gear and Feedback
Titus213
Oct 12, 2010 18:23 |  #14
Check batteries first.
I would also not expect 1/200 on the shutter. Some of the radio units can only manage up to 1/60.
Make sure the transmitter and receiver are on the same channel and the units are properly seated on the camera and the flash.
Dave
Perspiring photographer.
nes_matt
Oct 12, 2010 20:40 |  #15
So, earlier in the week I had a problem with mine too.
If you take the remote off the camera (or I suppose even on the camera) and you press the button on top, does the light on the front turn on? It should turn green at 1/2 press and red at full press.
Mine stopped working when I needed it... being frustrated I decided to pop it open and see what's wrong. I couldn't get it open, only partly. But that was enough somehow... it started working after that. Don't know why. I still need to pop it open to see why it stopped working...
1,721 views & 0 likes for this thread, 9 members have posted to it.
697 guests, 133 members online
