Hello
Does anyone have any useful links to somewhere that explains the differences between layers, layers via copy, layer from background etc etc.
Its confusing me.
Cheers
dpp Member 129 posts Joined Oct 2004 More info | Aug 25, 2005 11:39 | #1 Hello
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Aug 25, 2005 12:38 | #2 A layer is a layer, except that the background layer is not "layer-editable" unless you unlock it by Alt-Double-Clicking on the work Background in the layer toolbar. You can take my 100-400 L away when you pry it from my cold, dead fingers.
Mernya Member 146 posts Joined Jun 2005 Location: Los Angeles, CA More info | Aug 29, 2005 10:40 | #3 Layers via Copy, which is Ctrl-J, is the same as copying your selection, creating a new layer, and pasting on to it. -Mike
RAitch Goldmember 2,917 posts Likes: 9 Joined Mar 2005 Location: Sarnia Ontario, Canada More info | Aug 29, 2005 11:21 | #4 Layers Explained...
Mernya Member 146 posts Joined Jun 2005 Location: Los Angeles, CA More info | RAitch wrote: You can copy the contents of a layer (or selection) by using CTRL-C (or right-click or menus). This will copy the contents of the layer. Then you can press CTRL-V and a new layer will be created with that selection (layer via copy). Technically, that's the long way. Ctrl-J does all of that in one click and Layer Via Copy means that all you need to have done is made the selection (ie, whatever is masked). Hitting Ctrl J is the same as Ctrl-C, New Layer, Ctrl V. -Mike
RAitch Goldmember 2,917 posts Likes: 9 Joined Mar 2005 Location: Sarnia Ontario, Canada More info | Mernya wrote: Technically, that's the long way. Ctrl-J does all of that in one click and Layer Via Copy means that all you need to have done is made the selection (ie, whatever is masked). Hitting Ctrl J is the same as Ctrl-C, New Layer, Ctrl V. Try it, it's great. I know, I use CTRL+J all the time. Just trying to explain it in "common" terms.
| Latest registered member is semonsters 1681 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
